    Pi zero W sound
    pi zero audiogameboy zero
    9 Posts 3 Posters 4.1k Views
      archiver
      Hello, I am making a project, the adafruit super pi boy and have now problems with audio. I am using a pi zero w instead of a normal pi and have therefore no audio jack. I still intend to use the class d audio amp (TPA2016D2).
      I want to connect it directly to the gpio pins.
      Please advice
      • jonnykeshJ
        jonnykesh @archiver
        @archiver https://www.raspberrypi.org/magpi/rca-pi-zero/
          archiver
          this seems to work only for video, not sound
            cyperghost @jonnykesh
            @jonnykesh right! But that's the video part!
            @archiver I would advice a I2S amplifier or an exteranl USB sound card. Why? The analog output isn't good - you will have cracks and pops.
            EDIT:
            But @jonnykesh is on the right way. The GPIOs provide analog output!
            Here is how to do! https://www.raspberrypi.org/forums/viewtopic.php?t=127585
              archiver
              @archiver said in Pi zero W sound:
              TPA2016D2
              [https://www.adafruit.com/product/1712](link url)
              wouldn't this one work somehow?
              • jonnykeshJ
                jonnykesh
                  cyperghost @archiver
                  @archiver That's just an amplifier!
                  You've to restore the analog signal for this!
                  Me and @jonnykesh showed you three ways. Choose one - you are a free man.
                    archiver
                    my retropie instalation keeps resetting volume to 0... how do i prevent this?
                      archiver
                      failed to find mixer elements keeps popping up on terminal...
                      Also, can I use only my amplifier or do I have to copy everything exactly?
                      EDIT: I somehow got the audio to work via gpio, albeit with crackling... now to fix this
