    Not enough space + Cannot switch emulators (2 separate problems)
    ppssppspacescrapersdcardformat
    20 Posts 7 Posters 4.4k Views
      Collcroc123
      Whenever I try to scrape for game images and bios, it takes me to the command prompt saying there isn't enough space. Also what seems to be related to this is that when I play games with PPSSPP, I cannot save in game or use save states, as it says there is no more space. I've tried that step where you restore space in the Raspberry Pi Config, but that did nothing.
      My second problem is that with the N64 Emulators, I cannot change them. It's stuck on an emulator called "Mupen64plus-Auto" or something similar to that. I could not find any answers to this.
      • herb_fargusH
        herb_fargus administrators @Collcroc123
        @collcroc123 said in Not enough space + Cannot switch emulators (2 separate problems):
        Perhaps you are just out of space and need a bigger SD card?
          Collcroc123
          On my PC it says I still have over %50 empty space on the card
            mitu Global Moderator @Collcroc123
            @collcroc123 Is your PC running Linux ? The main partition where Raspbian and Retropie reside is a Linux type partition, which is not accessible from Windows. So unless your using a Linux PC, what you're actually seeing is a small boot partition, which is not the partition where your ROMs/saves are.
              Collcroc123
              This post is deleted!
                Collcroc123 @mitu
                @mitu My PC is running Windows 10
                  Collcroc123
                  So how can I fix the space issue?
                    ChuckyP
                    If you have a keyboard you can press F4 to exit to the command line interface.
                    You will see the available space on the SD card in that screen. As well as a bunch of other useful info like temps and such.
                    If you card is indeed full you will either need to remove some ROMs or artwork, or invest in a larger SD card.
                      Clyde
                      Another option is to run your ROMs from a usb drive.
                        Collcroc123
                        @ChuckyP @Clyde All the games I have are on a USB, and there is no artwork on the SD card, that's what I'm trying to put on.
                        I think the problem is that my MicroSD is split into 2 drives named boot (G:) and USB Drive (H:). G is like 50mb and H is like 8gb, and Retropie is on G. Not sure how to fix this either though.
                        • rbakerR
                          rbaker @Collcroc123
                          @collcroc123 You can't put it in a Windows machine. The sd card has 2 partitions:
                          The boot partition, which is quite small. This is the partition you see if you insert the sd card into a Windows system.
                          The linux partition, which holds the rest of the SD card size and where the ROMs are stored. This partition is not accessible from a Windows system.
                          If you try to copy your ROMs on the card, you'll be copying the on the boot partition, where obviously there isn't enough space.
                            Collcroc123
                            Ok so I followed a tutorial to fix the partitioning or whatever and suddenly both of my problems have been fixed!
                            Here was the tutorial.
                            https://raspberrypi.stackexchange.com/questions/1446/how-can-i-reformat-my-sd-card-to-use-it-normally-again
                              Collcroc123
                              So it WAS solved since I did that, it let me change the N64 Emulator and download images, but when I added some other emulators (Specifically Ports, PSP, MS DOS, Dreamcast, DS), now I can no longer change the N64 Emulator and all the images dissapeared. Not only that, I cannot save my game on PSP. I don't know what is causing it, if its one of the emulators or...
                              I think it may have to be for some reason Retropie only partions about 75mb for itself and leaves the other 7gb for nothing.
                                Collcroc123
                                So does that mean I can no longer properly use Retropie without a Linux machine? I used to be able to do all of this before on my Windows PC, so I don't seem to understand why it won't work anymore.
                                Also, the part of the MicroSD that Retropie is on says it has only used 21mb out of 56.8mb (when the whole card is about 8gb)
                                • quicksilverQ
                                  quicksilver @Collcroc123
                                  @collcroc123 how many games do you have on your card and from which systems? Did you put Dreamcast and psp games on? If so 8gb isn't going to be big enough. You are probably just running out of space and need a bigger card. You don't need Linux on your computer.
                                    Collcroc123 @quicksilver
                                    @quicksilver Yes I do have all those, I guess I'll try removing some. So even though the roms are on a USB, they get installed onto the SD card? Is it possible to set it up so the games stay on the USB and I just have to keep it in all the time?
                                    quicksilverQ ClydeC 2 Replies Last reply Reply Quote 0
                                    • quicksilverQ
                                      @collcroc123 https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
                                        Clyde @Collcroc123
                                        @collcroc123 You can check the occupancy of all mounted media with this command in Retropie's console. You get to the console by quitting Emulation Station without reboot or shutdown via the F1 menu or by just pressing F4.
                                        df -h
                                        Look for a line with "usb" in it, it should tell you the occupied percentage of the usb drive. If you don't understand the output, show it to us in a code block and we'll explain it to you.
                                        They will if you used the method @quicksilver and I linked to to set up the drive. You can check if any roms or other data remained on the sd card by booting Retropie without the usb drive connected to the Pi. You can then browse the contents of /home/pi/Retropie/roms and its subfolders with the pre-installed file manager mcin the command console. You can find a list of its hotkeys here.
                                          @quicksilver So I followed the instructions with a fresh version of Retropie, and it seemed to work, though I couldn't run N64. I go to install optional stuff like SMW, PPSSPP, and some others. When I exited, none of the things I installed appeared. I went back to the Retropie menu but all the images were missing and wouldn't let me open any settings. I tried to restart the system, and it told me there was no system found! It just boots me to the command line.
                                          • quicksilverQ
                                            @collcroc123 the systems don't appear in emulation station until you put ROMs the their folders
                                            Not sure why it's booting you to the command line...
