    Dreamcast Reicast, gamepad direction right doesn´t work under some conditions
    dreamcastdirectiongamepad
    3 Posts 2 Posters 598 Views
      rudeboy
      Hi together!
      I´m new to retropie and most things I tried works good.
      But I have an issue with Advanced Daisenryaku 2001 for Dreamcast.
      Gamepad works good in mapmode but in main menu and action menu for the units I can´t go right.
      Any idea?
      thank u and regards, rudeboy
      ps:no native english...
      • ShakzS
        Shakz
        Have you tried setting up the controller in the RetroPie menu?
        Retropie setup > Configuration / Tools > reicast
        or if you can log into your retropie....
        cd RetroPie-Setup
        sudo ./retropie_packages.sh reicastinput
        RetroPie tips, tricks, and tweaks: https://www.youtube.com/eazyhax
          rudeboy @Shakz
          @shakz said in Dreamcast Reicast, gamepad direction right doesn´t work under some conditions:
          cd RetroPie-Setup
          No, only in standard retropie Setup.
          Is there a special Reicast controller setup!?!?
