    Raspberry PI 3 B+ - WiFi help please
    wifi configraspberry pi 3b
    20 Posts 6 Posters 16.3k Views
    • namyzarkN
      namyzark
      Hi there, i have just received my new model of Raspberry Pi 3 B+. Unfortunately when I moved my Pi 3 disk image over, it didn't work. The screen show only the colored bars. I discovered the issue is with the Pi software image and, on a different sd card, installed the stretch image.
      https://retropie.org.uk/forum/topic/16307/retropie-4-3-15-stretch-images-for-testing
      I installed the stretch image successfully. However, I cannot get the wifi working on the B+. In the config menu when i search for wifi i have two options "0" and "H" for hidden essid. I put in my network id and password with wpa-2 password but it is unable to connect to my network.
      In the thread that's linked above, with the download for the stretch image, the poster explains this very issue, as well as the resolution for it, which is to set the country code. I've set mine to US. Both through the retro pi config, and directly on the wpa_supplicant.conf file.
      It's still not working. I get no options as if the Pi is not seeing any wifi. I know it can see WiFi, as when I do the NOOBs install it sees the wifi just fine.
      Here is my config:
      ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
      update_config=1
      country=US
      RETROPIE CONFIG START
      network={
      ssid=""
      RETROPIE CONFIG END
      Help?
      jonnykeshJ BuZzB 2 Replies Last reply Reply Quote 0
      • jonnykeshJ
        jonnykesh @namyzark
        @namyzark The answer is literally under the download links.
        Note for WiFi on the new Raspberry Pi 3 Model B+:
            WiiFi is disabled until wireless regulatory domain is set (Pi 3 B+ only)
            - The domain can be done through 'Raspberry Pi Configuration' (rc_gui),
            'raspi-config' or by setting 'country=' to an appropriate ISO 3166
            alpha2 country code in /etc/wpa_supplicant/wpa_supplicant.conf.
        Your file should look like this
        country=GB
        update_config=1
        network={
        	ssid="myssid"
        	psk="mywifipassword"
        • F
          Flexserve @jonnykesh
          @jonnykesh said in Raspberry PI 3 B+ - WiFi help please:
          GB
          Use: US - for United States (for those that live there)
          jonnykeshJ 1 Reply Last reply Reply Quote 1
          • jonnykeshJ
            jonnykesh @Flexserve
            @flexserve I believe that was implied.
            • F
              Had a lot more written, but edited. Just trying to help, but that too was implied.
              • jonnykeshJ
                @flexserve No one is here to hold people's hands. They should be able to figure basic stuff out for themselves.
                F BuZzB 2 Replies Last reply Reply Quote -1
                • F
                  @jonnykesh I'm not going to argue with you. That's a pretty bad and toxic outlook for a "help forum". Good luck, peace out.
                  Edit: Salty down vote appreciated. I think it is best we don't communicate any longer. Not worried about points here. I'm here to help.
                  jonnykeshJ 1 Reply Last reply Reply Quote 3
                  • jonnykeshJ
                    @flexserve This is not a "help" Forum. This is a forum for users of RetroPie.
                    A certain amount of understanding is expected, as is some reading.
                    I'm sure the person I was actually replying to, not you, could figure out that they are not in the UK, but the US.
                    Give people some credit.
                    BuZzB 1 Reply Last reply Reply Quote -1
                      BuZz administrators @jonnykesh
                      @jonnykesh think your comment is uncalled for and overly abrasive. Also you didn't read the original post. The user already tried changing the country.
                      jonnykeshJ 1 Reply Last reply Reply Quote 2
                        @jonnykesh no - you don't decide what this forum is for thanks. It is a help forum also for RetroPie users.
                        • jonnykeshJ
                          jonnykesh @BuZz
                          @buzz Okay with me.
                          • jonnykeshJ
                            jonnykesh @BuZz
                            @buzz If you read OPs post you will see that he hasn't even input his SSID or password details or his file would not look like that.
                            So, he has set his Wifi country. Yet, has not bothered entering the actual details of his WiFi network.
                            Anyway.
                            BuZzB namyzarkN 2 Replies Last reply Reply Quote 0
                              @jonnykesh That's not why he can't see his network. He has no details in there as no networks are showing up.
                              • jonnykeshJ
                                jonnykesh @BuZz
                                @buzz that's exactly how it will look if he hasn't actually entered his WiFi details.
                                Anyway, as I said, I was trying to help.
                                Some people here seem to underestimate others.
                                  BuZz administrators @namyzark
                                  @namyzark if you drop to a command prompt - what's the output of
                                  apt-get install rfkill
                                  iwconfig
                                  rfkill list wlan
                                  did you reboot after changing the wifi country via raspi-config btw ?
                                  • namyzarkN
                                    namyzark @jonnykesh
                                    @jonnykesh As I stated in my original post, I've set the country code. You can see that in the copy of my config I posted. It's set to "US". It hasn't changed the fact that I can't scan for networks available.
                                    I did have the SSID and password there. I deleted out the SSID & Password details so as not to share the details of my home network. I've put in my SSID & Password as well. It still has not connected to my WiFi.
                                    I've copied the file from my working Pi 3, which I know connects to my wifi without issue.
                                    Yes, I have rebooted. I've also taken the card out, checked the details, etc.
                                    No, I don't have an ethernet cord plugged in.
                                    @BuZz The results are as thus
                                    rfkill is already the newest version (0.5-1).
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    • lo no wireless extensions
                                      wlan IEEE 802.11. ESSID:off/any
                                      Mode:Managed. Access Point: Not-Associated
                                      Retry short limit:7. RTS the:off. Fragment the:off
                                      Encryption key:off
                                      Power Management:on
                                    0: phy0: Wireless LAN
                                    Soft blocked: yes
                                    Hard blocked: no
                                      mitu Global Moderator @namyzark
                                      @namyzark said in Raspberry PI 3 B+ - WiFi help please:
                                      Soft blocked: yes
                                      Maybe that's the problem. Can you try running sudo rfkill unblock all and then re-run sudo rfkill list all ?
                                      You should get at least 2 interfaces listed:
                                      0: hci0: Bluetooth
                                      	Soft blocked: no
                                      	Hard blocked: no
                                      1: phy0: Wireless LAN
                                      	Soft blocked: no
                                      	Hard blocked: no
                                      namyzarkN 1 Reply Last reply Reply Quote 3
                                      • namyzarkN
                                        namyzark @mitu
                                        @mitu That did the trick! I immediately got on the wifi and pulled an IP. Router confirms it's hooked up.
                                        It is now on the network. I also rebooted just to ensure it would stay enabled. It did. Yay!!!
                                        Thank you @mitu !!!
                                          @namyzark Glad you got it working. I think @buzz nailed it with the diagnostics, I never would have thought rfkill would be enabled on a Pi, always thought this would be useful for laptops with dedicated wifi kill switch.
                                          • E
                                            esadbih187 @mitu
                                            @mitu just had same problem and I know nothing thank you, never would have figured that out.
