    GBA roms not starting on Ras Pi Zero W
    biosgba
    20 Posts 3 Posters 5.8k Views
    • H
      Hellasius
      Hello Everyone,
      I recently made a home made gameboy with a pi Zero W. I succeded to run som roms, but doesn't with other (like pokemon Red Fire or Golden Sun)
      I puted the gba_bios.bin file into BIOS directory. I tried to run with GPSP and MGBA, but the game is not stating.
      I went to retropie_setup.sh but I don't find any line for lr-vba-next or something else.
      I think that I am not the first one to have this problem, but I am a neebie with Retropie and I can not find any real solution for my problem.
      Any help would be very appreciated.
      Hellasius.
        mitu Global Moderator @Hellasius
        @hellasius Make sure your BIOS is correct - verify the checksum on https://retropie.org.uk/docs/Game-Boy-Advance/ is the same as your bios file.
        Second - https://retropie.org.uk/forum/topic/3/read-this-first - what image and RetroPie release are you using ?
        You should find the emulator log file in /dev/shm/runcommand.log, so find the file after you've tried to run the ROM and post its contents on pastebin.com, then post the link here.
        • H
          Hellasius @mitu
          @mitu Thank you for your help
          1. my md5sum is a860e8c0b6d573d191e4ec7db1b1e4f6 => OK
          2. I am runing retropie-4.3-rpi1_zero image from https://retropie.org.uk/download/
            I have nothing in /dev/shm/ the folder in empty...
            @hellasius said in GBA roms not starting on Ras Pi Zero W:
            Check the folder immediately after running the failing ROM, the log file does not exist before and it's also cleared when you restart your system.
            H 2 Replies Last reply Reply Quote 0
            • H
              Hellasius @mitu
              @mitu https://pastebin.com/t73imqSf
              • H
                Hellasius @mitu
                @mitu You will certainly ask, so here is my config.txt
                https://pastebin.com/wtfbHigD
                I change it to be woring with my piTft 2.2 from adafruit, but I might have delete a importante line.
                  @hellasius Does it work if you remove the overclock ? The log file has some errors regarding audio, I'm not sure they're the cause of the crash.
                  • H
                    Hellasius @mitu
                    @mitu I tried to remove the firt part of the config.txt
                    did no change anything. https://pastebin.com/n9QY7FfZ
                      @hellasius Can you try a different ROM ? Are you sure the ROM(s) that fails is ok ?
                      • H
                        Hellasius @mitu
                        @mitu I tried different ROMs,
                        pokemon red fire frensh or english, golden sun, sims 2 are not working.
                        but Mario and zelda minish cap are working fine.
                        I am not 100% sure but ROMs are from dfferent website.
                        I don't think is come from the ROM. But I will try other one to be sure.
                          @hellasius Try to enable the verbose logging in the Runcommand menu, maybe the log would be more detailed. Does your sound work ?
                          • H
                            Hellasius
                            I tried with another ROM for pokemon ruby and I have the same issue.
                            I run the ROM with verbose command, same. Where can I find the error file? that I can share it with you.
                            I do not have a daptater for mi Pi zero to try the sound., I don't know if it's working.
                              Same file as before - /dev/shm/runcommand.log.
                              • H
                                Hellasius @mitu
                                @mitu haha sorry I feel so noob ^^'
                                https://pastebin.com/B5pVNvGN
                                Thank you for your time by the way !!!
                                cyperghostC mituM 2 Replies Last reply Reply Quote 0
                                  cyperghost @Hellasius
                                  @hellasius Do you see text like 1679/ -/ Pokemon/ Rouge/ Feu/ (F)(Rising Sun).gba in the grey box if you start your ROM?
                                  Look at the slashes /
                                  • H
                                    Hellasius @cyperghost
                                    @cyperghost No there is no /
                                      @hellasius Okay thank you! That was my problem for round about one year or so :)
                                        @hellasius The log file doesn't seem to report any errors, but have you tried to see if the ROM is ok ? Load it in another emulator - on a PC maybe ? - to see if it works.
                                        • H
                                          Hellasius @mitu
                                          @mitu I quicklly tried to run my ROMs on PC emulator, but none are working (not pokemon and not zelda, that was supposed to work)...
                                          I am lost...
                                          • H
                                            Hellasius
                                            Roms are all working on my PC.
                                            I realize it was just a issue during the transfert of the rom to my raspberry, now it should work.... but actually my raspberry pi seems not to respond to my SD card.
                                            I tried to reboot on the new retropie IMG, and nothing. Green led blink twice, then nothing.... when I try the same SD card on another pi It's working.
                                            If you have any advice for this issue, that would be great.
                                            You already helped me a lot. Thank you.
