    No Sound in AdvMame 3.7
    advmamesound
    3 Posts 2 Posters 1.0k Views
    • U
      UrbanDragon
      Hey folks, wondering if anyone else has seen this.
      RetroPie is 4.3.17
      I've a Pi 3 B, with Canakit Pi power supply, Built from RetroPie.org.uk image download, upgraded through Setup script, X Gaming Tank Stick, USB Devices: Hub, Tankstick, Trackball, Spintrak Spinner, USB SoundBlaster.
      The issue is specific with AdvMame 3.7 - there is no sound in it - I've got it setup t play vector games like Tempest. If I use AdvMame 1.4 sound is fine, just with 3.7 (I've updated through the RetroPie setups to the latest) none. LibRetro emulators (SNES, Mame 2003/2010, NES, etc.) all play sound without a problem.
      I still need to test with the built in headphone jack, curious if anyone else has seen this with an external sound device?
      Thanks.
        mediamogul Global Moderator @UrbanDragon
        @urbandragon
        Your soundcard should be compatible with the 'alsa' setting. You might want to look here to see if setting 'device_alsa_device' from 'default' would help. You could also try setting 'device_sound' to 'sdl' in your advmame.rc.
        • U
          UrbanDragon
          Thank you, setting it to SDL worked. I never would have thought to try that.
          I think that they modified something in Advmame as it was working prior to one of the updates with 3.x then just nothing and still worked with 1.4 with Alsa.
