    RPI 3B+ + HDMIPI - Powerboost 1000C - Help!
    raspberrypi 3b+adafruitpowerboosthdmipi
    12 Posts 2 Posters 2.7k Views
    • Drakaen391D
      Drakaen391 @davidpearl
      @davidpearl looking closer into the setup, your power source may be the issue... how many amps are being sent to the board (use a multimeter)
      RPi B & RPi 3B OC (Now Raspberry pi 4b 8gb)
      Retropie (Latest Stable)
      PiBox with Wind Tunnel Cooling System
        davidpearl @Drakaen391
        @drakaen391 the power source is 5v 2a (Raspberry Pi official power supply)
        If I bypass the powerboost 1000c the power supply works perfect in the hdmipi driver board back powering the pi.
        The issues occur when I introduce the powerboost I to the circuit.
        I can try:
        5v 2A ps -> powerboost 1000c -> step up converter to 12V -> HDMI Driver board -> Rpi
        Would that work?
        Drakaen391D 1 Reply Last reply Reply Quote 0
        • Drakaen391D
          @davidpearl not through the 5v plug
          Test the amps and output voltage coming out of the power block to see if it’s working properly...
            @drakaen391 not sure what you mean (I'm not massively technical)
            I have checked the voltage from:
            Powerboost to hdmipi with step up to 12v
            hdmipi to raspberry pi with 5.1v step up
            • Drakaen391D
              Drakaen391
              so, energy that is drawn by an electronic is based on 2 things.... Voltage, which is constant and amperage which is dynamic with an upper limit based on the power supply used....both together make up wattage...
              The official power supply sends out 5v of power and has a max amperage output of 2.4amps
              The raspberry pi 3B requires the 5v and about 2 amps to turn on anything under that and it won’t work
              The powerblock you have could be dropping the amperage to below the threshold needed for the Pi to turn on...
              A multimeter with Amp function can diagnose if the output is still at the correct level or not...
              D Drakaen391D 2 Replies Last reply Reply Quote 0
                @drakaen391 thanks, I don't have anything that can read amperage
                Assume I could get a 5v power supply with say 4A to cover myself?
                • Drakaen391D
                  Drakaen391 @Drakaen391
                  @drakaen391 you might be able to borrow it from a friend or rent one from autozone.... just make sure it can read amps
                  • Drakaen391D
                    @davidpearl you could especially with the pull but still recommend a multimeter in case it’s a bad board
                      @drakaen391 cheers.
                      Just bought this
                      link text
                      • Drakaen391D
                        @davidpearl not bad... basic and works for what you need
