    Splash screen no audio.
    splashsceenaudio issueshelp me
    18 Posts 3 Posters 6.5k Views
    • H3rmitPl4ysH
      H3rmitPl4ys
      So I have set a mp4 splash screen as my splash screen for retropie but I am getting no audio. I'm using USB speakers because my monitor has no speakers . I can't use HDMI or anything else. I already bought USB speakers for my Raspberry pi B+ and I set them up and I get audio out of them in emulation station. However, I get no audio when the splashcreen plays. I get video but no audio. I have heard that omxplayer doesn't support USB devices. But I just wasn't sure if there is a way I can get around that.
      Any ideas? Thanks.
        mitu Global Moderator @H3rmitPl4ys
        @h3rmitpl4ys Does playing the file from the command line with omxplayer work with audio ? Exit Emulationstation, then run from the command line
        omxplayer `path/to/file`
        and see if any audio comes out.
        • H3rmitPl4ysH
          H3rmitPl4ys
          I would do this but I'm not sure what you mean. How do I run the file from the command line?
            @h3rmitpl4ys As I sais, exit Emulationstation and you'd be exiting to the command prompt, where you can type the command I mentioned - do you have a keyboard attached to the Pi ?
            • H3rmitPl4ysH
              H3rmitPl4ys
              Yes I have a keyboard hooked up to the Pi. When I type in this command It says: File "/path/to/file" not found. I have tried Sudo Nano before this also but It pops up blank. Am I doing something wrong?
                @h3rmitpl4ys You'll need to replace /path/to/file with the actual path to the video file, that's meant to be a placeholder so you can see how the command works.Where did you copy your video file ?
                H3rmitPl4ysH 1 Reply Last reply Reply Quote 0
                • H3rmitPl4ysH
                  H3rmitPl4ys @mitu
                  Ah, gotcha. Where did I copy my video file? Is that where I would have downloaded the file?
                    @h3rmitpl4ys said in Splash screen no audio.:
                    Yes, the location on the Pi where the video file is located, you either downloaded it directly there or copied it from your PC/USB stick.
                    • H3rmitPl4ysH
                      H3rmitPl4ys @mitu
                      @mitu I used my PC and got the Mp4 file off a website and I connected through LAN so I used the IP from My PI and placed the Mp4 file into the splash screen folder.
                        @h3rmitpl4ys So the file should be in /home/pi/RetroPie/splashscreens. List the folder's contents with the command
                        ls /home/pi/RetroPie/splashscreens/
                        note the filename and then run omxplayer with
                        omxplayer /home/pi/RetroPie/splashscreens/filename.mp4
                        replacing filename.mp4 with the actual name of the file. Do you get any audio ?
                        • H3rmitPl4ysH
                          H3rmitPl4ys
                          Just tried it, It pops up and plays the splash screen but there is no audio.
                            @h3rmitpl4ys OK, so that's the command run at the beginning. You need to pass to tell omxplayer which audio device to use, so run the command like
                            omxplayer -o local /home/pi/RetroPie/splashscreens/filename.mp4
                            If you get audio, it means the USB soundcard is detected and working. Try to apply the advice in https://www.woltersadvertising.com/how-to-set-default-raspberry-pi-sound-output-to-usb-device-on-raspbian-jessie-and-retropie/ to change the default audio output from the built-in HDMI audio to the USB soundcard.
                            • H3rmitPl4ysH
                              H3rmitPl4ys
                              I'm still not getting audio even when adding the -o local. It's weird because I get audio when playing games and in the menu. yet I don't on the splash screen.
                                @h3rmitpl4ys omxplayer can be directed to the correct audio device with the -o parameter
                                 -o  --adev  device          Audio out device      : e.g. hdmi/local/both/alsa[:device]
                                Check which Audio device you have set in Emulationstation and try to specify it in the command line to test if it work. Alternatively you can run aplay -l to see the available devices in the system to determine which one is the USB.
                                Once you find the right parameter value, then you can modify the splashscreen command and add it there also.
                                But have you checked the link I posted for making the USB soudcard the default ?
                                • H3rmitPl4ysH
                                  H3rmitPl4ys
                                  @mitu I just did something by accident. I did the first command you told me to do but instead of local I changed it to asla. And what do you know I get sound! Now all I gotta do is figure out how to get the actual splashcreen working!
                                    @h3rmitpl4ys The splashscreen is started from /opt/retropie/supplementary/splashscreen/asplashscreen.sh, you could edit the script and modify line 35 so instead of
                                    omxplayer -o both
                                    it's started with
                                    omxplayer -o alsa
                                    It's not the most elegant solution, but give it a try.
                                    L 1 Reply Last reply Reply Quote 1
                                    • H3rmitPl4ysH
                                      H3rmitPl4ys
                                      @mitu Thanks so much!! It finally works! I get sound when I boot it up!
                                      • L
                                        LionSquall @mitu
                                        @mitu I know you do not like to revive post but thanks for this help
                                        • VirgoHV VirgoH referenced this topic on
