    Vice slow and stuttering sound
    vicec64slowlinux mint
    8 Posts 4 Posters 3.4k Views
    • 1
      10vorne
      Hi,
      I installed vice for the C64 retropie on my Linux mint, but the games run slow and sound is suttering. As Hardware I'm using a slow Samsung N150 Netbook, but SNES runs smoothly without performance issues. Maximum speed is set to 100%, Refresh rate to automatic. Any ideas what I could try to or is the Netbook to slow for a good experience with vice?
      edmaul69E BuZzB 2 Replies Last reply Reply Quote 0
        edmaul69 @10vorne
        @10vorne i use lr-vice. No slowdown or stutter. Its a big reason why i hated standalone vice. Plus lr-vice lets you use a virtual keyboard and analog stick for a mouse.
        • 1
          10vorne
          Ok, you are right. I got no issues with lr-vice. But the mouse stops in the upper before the upper 1/3 of the screen, so the mousepointer stops at an invisble wall. And I cannot move the pointer with my usb-pad (without analog stick). So for example I cannot swap joystick ports. It seems not possible to control the gui without a mouse or an analog stick?!
            BuZz administrators @10vorne
            @10vorne Try switching to the faster sid emulation. There are a few options in the settings that can affect performance. The default SID emulation on X86 is quite CPU intensive.
            • 1
              10vorne
              Hi BuZz, thanks for joining. You mean the sid settings in vice-x64 or lr-vice? In x64 I did not find any Sid-Settings and there are no perfomance problems in lr-vice. Or did I get you wrong?
                mediamogul Global Moderator @10vorne
                @10vorne
                He's likely talking about the standalone vice-x64. You can disable reSID emulation to get a boost in performance at the cost of some accuracy in sound chip emulation. This is probably already set in lr-vice, which would explain the performance boost despite the added overhead that RetroArch introduces. I have reSID emulation enabled on mine and haven't witnessed any slowdown on my Pi3B, but it could be that your netbook's performance falls below that mark.
                • 1
                  10vorne
                  That means, that the disable-option is not part of the vice-x64 in emulationstation, correct?
                    @10vorne
                    It's part of vice-x64, but Emulation Station doesn't factor into it. It's set from within the vice-x64 settings menu.
