Reicast - Using The Same evdev_device For Multiple Players
Model: Raspberry Pi 3 B+
Power Supply: Canakit
RetroPie Version: 4.4
Build: Pre-Made SD from Retropie
USB Devices: Dell Keyboard (I don't think this is relevant but it doesn't hurt to add)
Controller: I have the pins from an old 12-in-1 Midway Arcade Machine from ~2007 plugged into the GPIO, and I'm using Retrogame to parse the inputs (If you look at the readme and see the RetroPie 2.0+ Compatibility section, don't worry I already did that, also if you want a quick synopsis on how retrogame works, it takes your GPIO inputs and converts them into keyboard presses with a device name of "retrogame"). The old midway has 2 sets of a 4-way Joystick and 6 buttons.
Error Messages: 989 Trace/breakpoint trap "$rootdir/emulators/reicast/bin/reicast" "${params[@]}" > /dev/null
Emulator: ReicastSo, if you read above, I am using retrogame to parse two sets of controls at the same time as keyboard presses. This works great for both players in RetroArch, and 1 player in Reicast by commenting out the autoconfig line in reicast.sh and relying on the mappings file I made. The issue arises when I try to set both evdev_device_id1=1 and evdev_device_id2=1, I get the error above in $rootdir/emulators/reicast/bin/reicast.sh line 88 (EOF) in runcommand.log, and then the game doesn't load. As I said, if I set evdev_device_id1=1 and evdev_device_di2=-1 (No Input), the controls work fine, and I also have different mapping files for both players in evdev_mapping_1 and evdev_mapping_2. I was wondering if there is any solution, as I feel as though some adjustments in the emu.cfg parsing code in reicast.sh can fix the issue, but I have no clue where to start.
Looks like a
reicastproblem, not accepting the same device_id for both players.
Have you tried using the mkarcadejoystick driver to map your inputs to 2 different gamepads ? IMHO this would be much cleaner instead of relying on the emulated keyboard that Retrogame supplies. You can install the driver from the RetroPie-Setupdriverssection of the packages. The github page of the project has documentation on how to load the driver and configure the gamepads. -
Alright this seems promising, but I cannot figure out how to map a custom gpio config for multiple players. In the readme, there's an option to use map=5 and gpio=..., but this seems to only work with one player. Does anyone know of a way to custom map both controllers through mkarcadejoystick?
@mememinister , I am trying to do the same thing but can't get my mapping working manually. Only through the ES menu Configuration Input. Do you do your mapping in es_input.cfg or in retroarch.cfg? My retroarch.cfg gets ignored or at least that is what it seems like. Do you have a little manual how you did the mapping?
