    Help, missing psx rom
    psx roms
    4 Posts 2 Posters 880 Views
      Tackskull
      Hello everybody, nice to met you.
      I have a little issue with my psx system on retropie. I am using a laptop running linux ubuntu.
      All my systems works very well, but I put so many playstation roms on the psx rom folder but just 4 of them result on the game list. I have read a lot of forums and I got that the most common issue was because the file .bin was needing a file .cue
      The point is that all my playstation games are shared with a .bin and a .cue file, and cant really understand why "alundra, medievil, castlevania and xenogears" are the only games showing up of the 30 games I loaded.
      Maybe I did some bad stuff playing with the retroarch options, in fact I tried to remove and reinstall the psx system, but the situation is the same.
      What I have to do? Please help
        Tackskull @Tackskull
        @tackskull
        Guys, the same problem is happening with the snes
        too, what is happening? Did I some trouble with some option who doesnt let me add other roms?
          Make sure your ROM files are named with the proper extension so that ES can show them in the list of games. If you look in the Docs, each emulator/system has a list of file extension supported.
          Make sure you haven't turned on the Parse metadata only option in Emulationstation, check the filenames extensions and restart Emulationstation once you've added the ROMs.
            Tackskull @mitu
            Awesome man!!! Thanks, was that suckin show metadata only.
            Thanks a lot
