    [Experiment] Touchscreen calibration settings that work in Pixel Desktop (Raspbian) doesn't work in Retropie..
    touchscreenretropie 4.4xpt2046pixel desktop
    7 Posts 2 Posters 1.4k Views
    • felixlee0530F
      felixlee0530
      Hi all,
      I recently bought a Raspberry Pi 3 and a 5-inch LCD display with resistive touch.
      The touch display uses XPT2046 touch controller, so I installed some set of touch drivers and calibration application in the Pixel Desktop (Raspbian) which I installed separately, and checked that the touch function works fine for all of the surface of the display in the Pixel Desktop.
      Here is the link that I looked at to install touch drivers: https://www.raspberrypi.org/forums/viewtopic.php?t=143581
      However, when I tried to do some touch operation in Drastic in Emulationstation, I found that touch with a stylus actually works in the game display, but the calibration is somewhat messed up.
      Is there any methods to apply the SAME calibration settings with the Pixel Desktop, so that touch in a certain position of the display may work in the exact same way as in Pixel Desktop?
      Sample touchscreen calibration settings using xinput_calibrator:
      Section "InputClass"
      Identifier "calibration"
      MatchProduct "ADS7846 Touchscreen"
      Option "Calibration" "3853 170 288 3796"
      Option "SwapAxes" "1"
      EndSection
        mediamogul Global Moderator @felixlee0530
        @felixlee0530 said in [Experiment] Touchscreen calibration settings that work in Pixel Desktop (Raspbian) doesn't work in Retropie..:
        DraStic is not written to support absolute pointer coordinates. Unfortunately, it only supports relative mouse coordinates, which will allow the touchscreen to work, but you'll always have to drag the cursor around to get it where you want it.
        • felixlee0530F
          felixlee0530
          This post is deleted!
          • felixlee0530F
            felixlee0530
            @mediamogul said in [Experiment] Touchscreen calibration settings that work in Pixel Desktop (Raspbian) doesn't work in Retropie..:
            Are there other alternatives of Drastic in Emulation Station that support touch calibration?
              @felixlee0530
              I'm afraid not. There's lr-desmume, but I don't believe it supports pointer input either. Even if it did, it really doesn't run any games past a few frames per second on the Pi.
              felixlee0530F 1 Reply Last reply Reply Quote 0
              • felixlee0530F
                felixlee0530 @mediamogul
                @felixlee0530
                Yeah.. I guess.. but Desmume actually runs Pokemon Platinum quite well, maintaining 100% speed.
                  @felixlee0530
                  Good to know. I tried a handful of games a while back and didn't have any luck myself, but it makes sense that some of the less demanding games would be playable. What kind of frame rates were you getting?
