    8bitdo SNES30 Bluethooth Input Issues
    22 Posts 8 Posters 38.1k Views
      MaximumCarnage
      I apologize, I'm very new to RetroPie, I just set it up over the weekend. I bought an 8bitdo SNES30 bluetooth controller, and am having trouble being able to get RetroPie to recognize any input that aren't the D-Pad controls. I have no issues at all pairing it, which is great, but only the D-Pad works, so I can't really even try to configure it.
      If I remove the SNES30 as a Bluetooth device and run it using the USB cord it came with, I run into no issues at all.
      Pi Model: 3
      RetroPie Version Used: 3.8.1
      Built From: SD Image/Binary (Updates)
      USB Devices connected: Keyboard [SNES30 sometimes]
      Controller used: 8bitdo SNES30 controller
      Error messages received: N/A
      Guide used: https://www.reddit.com/r/RetroPie/comments/3avin0/retropie_8bitdo_sfc30/ (for troubleshooting, but no luck. Did create 10-local file)
      File: N/A
      Emulator: N/A
      How to replicate the problem: Pair 8bitdo SNES30 controller with Bluetooth. D-Pad will work, no input buttons will.
        Go to the bluetooth menu, remove all devices so that none are registered. Press R + Start on controller and hit enter to start scan. The one that says 8bitdo SFC30 Gamepad Joystick, select that and use the first pairing mode. Follow this guide for more help.
        https://github.com/retropie/retropie-setup/wiki/Setting-up-a-Bluetooth-controller#manual-bluetooth-configuration
        Y 1 Reply Last reply Reply Quote 0
        • Y
          yoink @lilbud
          @lilbud I've done that, but still no go. What firmware is your SNES30 on? I'm running v2.68Beta5 and the D-Pad works, but nothing else. Very frustrating. Should I downgrade to 2.67? What mapping config are you using for two controllers?
            pimpmaul69 @yoink
            @yoink did you follow the tutorial for making the etc/udev/rules.d/10-local.rules file? It will not recognize anything else on the controller if you didnt do that. here is what you needin the file. changecontroller name to your controller type:
            edit: Fixed code
            # Add the ID_INPUT_JOYSTICK attribute to the device so SDL picks up on it
            SUBSYSTEM=="input", ATTRS{name}=="8Bitdo NES30 GamePad Joystick", MODE="0666", ENV{ID_INPUT_JOYSTICK}="1"
            mediamogulM Y 2 Replies Last reply Reply Quote 0
              mediamogul Global Moderator @pimpmaul69
              @pimpmaul69 said in 8bitdo SNES30 Bluethooth Input Issues:
              there is a hashtag and a space right before the word add. not sure why the forum is removing it
              Markup nuances can be frustrating. Here's a link that might be of help in future postings:
              http://commonmark.org/help/
                pimpmaul69 @mediamogul
                @mediamogul said in 8bitdo SNES30 Bluethooth Input Issues:
                Sometimes the 4 spaces doesnt work for me. Not sure why? I think i got it working this time.
                • Y
                  yoink @pimpmaul69
                  @pimpmaul69 Yes I added the file using the setup utility.
                    @pimpmaul69
                    Both the 'Blockquote' and 'Inline code' specifics are referenced in the link I posted. I believe you were intending to post 'Inline code'.
                    Edit: You got it. Score one for the good guys.
                      pimpmaul69 @yoink
                      @yoink said in 8bitdo SNES30 Bluethooth Input Issues:
                      and you held down the right trigger before and while powering on the controller? that is the mode it has to be synced in and booted in. i got the nes30 working on the 1.69 just fine this way. i believe the 2.68 is the equivelant version. if you are just powering on only, that mode does not work and gives a keyboard only input on the pi.
                      • Y
                        yoink @pimpmaul69
                        @pimpmaul69 Yes I used the Start + R method. I followed the instructions in this post:
                        http://www.austinjmorlan.com/2016/04/8bitdo-snes30-retropie-36.html
                        Which recommended the 2.68 Beta firmware.
                        • theroamerT
                          theroamer
                          You need to edit the config file here: /opt/retropie/configs/all/retroarch-joypads/
                          for the nes30pro it's called 8BitdoNES30ProJoystick.cfg for yours it will prob say snes 30. You need to change the numbers to correspond to your controllers numbers. You can get this info by running:
                          jstest /dev/input/js0
                          and test each button for the number.
                          • Y
                            yoink @theroamer
                            @theroamer So I finally got the SNES30 controllers to work. The key was to downgrade the firmware to stable 2.67. Afterwards, I removed them from RetroPie, repaired them and then setup the controllers via ES and now everything works.
                            Here's a copy of the config:
                            input_device = "8Bitdo SNES30 GamePad Joystick"
                            input_driver = "udev"
                            input_l_btn = "17"
                            input_load_state_btn = "17"
                            input_start_btn = "22"
                            input_exit_emulator_btn = "22"
                            input_up_axis = "-1"
                            input_a_btn = "11"
                            input_b_btn = "12"
                            input_reset_btn = "12"
                            input_down_axis = "+1"
                            input_r_btn = "18"
                            input_save_state_btn = "18"
                            input_right_axis = "+0"
                            input_x_btn = "14"
                            input_menu_toggle_btn = "14"
                            input_select_btn = "21"
                            input_enable_hotkey_btn = "21"
                            input_y_btn = "15"
                            input_left_axis = "-0"
                              Abstract3000
                              Same issue here Retropie straight out of the box at the 3.8 download you will need to downgrade the firmware to 1.68, "But" if you go into the RetroPie Menu and download the latest config file, you will then need to upgrade back to 1.69 or 1.70 (as it appears they have made recent changes)
                              • Y
                                yoink @Abstract3000
                                @Abstract3000 I'm going to hold off on any beta firmware from 8bitdo until it's stable. Is 1.70 beta working for you? What changed?
                                  Abstract3000 @yoink
                                  Yeah it seems to work fine, It is the firmware my controller was shipped with. from what I have read it only improved the following:
                                  1.Improve automatic connection.
                                  2.Make the LED blink much quicker when the controller is in auto-connect status.
                                  and I can say with 1.70 installed retropie synchs much quick with it.
                                  • Y
                                    yoink
                                    I wouldn't expect a controller to ship with beta firmware. Are you using this firmware? http://forum.8bitdo.com/thread-1179-1-1.html
                                      BuZz administrators
                                      Just FYI, I have a couple of controllers that the retroarch mapping doesn't work for, but without our "workaround" for the older firmware it does, so I will introduce an option in the bluetooth settings to switch this behaviour. It will need to be changed "before" settings up your controls.
                                      • Y
                                        yoink @BuZz
                                        @BuZz Is that related to the issue I've been having with the 2.68 Beta firmware for the SNES30?
                                          BuZz administrators
                                          I hope so.
                                          • Y
                                            yoink @BuZz
                                            @BuZz So when I used my SNES30 controller with 2.68Beta5 firmware, ES was fine, but Retroarch and all the games only the D-Pad worked. Only by downgrading to 2.67 stable did the controllers work again in Retroarch after unpairing, pairing, then setting them up in ES. Should I update Retropie to fix this issue addressed here? If so, what method should I use?
