    Is it possible to have Retropie switch a servostik from 4-way to 8-way automatically?
    servostikmame
    4 Posts 4 Posters 1.7k Views
    • U
      UnicornsOnLSD
      I know that MAME can keep info on the stick configuration of each game, is these a way to tell the servostik to automatically change based on this? I know that attract-mode has a system that can do this.
      • H
        Headrush69
        There is 3rd party support for Ultimarc products in Linux here: https://katiesnow.webs.com
        As of the last update in 2016, it says Servostik support was planned.
        Might be worth contacting the author there and see if any progress has been made.
        • stoney66S
          stoney66
          @UnicornsOnLSD
          So i got this working using katies software, she didn't have the json/configs in her repo but the code is there for the servostik. I just used the json config below to switch modes.
          https://github.com/katie-snow/Ultimarc-linux
          "version" : 2,
          "product": "servostik",
          "switch" : 4
          Switch value is 4 or 8.
            SloTayHolmes @UnicornsOnLSD
            @unicornsonlsd
            I did this using the RGB Commander utility. It sets the servo stick from 4/8 way automatically depending upon the game you launch in MAME.
            DISCLAIMER: I'm using RGB Commander v.3 with one of the older RetroPie Jessie images. Haven't tested the current v.4 with the newest RetroPie 4.4 Strech image. Might be worth a try though!
