    Mega-Tech theme for Sega based builds
    mega-techmegatechthemesegamegadrive
    39 Posts 20 Posters 16.7k Views
    • ruckageR
      ruckage
      I've uploaded the theme to mega.nz for those who would like to try it.
      DOWNLOAD
      I've not had a chance to try this modified version on a raspberry pi but it should work fine. Let me know if you have any problems though.
      There are a few settings you can modify in the config.xml file:
      REGION: 'region-europe' or 'region-usa'. Affects certain systems icons and logos. e.g Megadrive or Genesis. Default is 'region-europe'
      SCALING: 'image-fit' or 'image-stretch'. Affects how preview images/videos are scaled. 'image-fit' will maintain the aspect ratio of the image. 'image-stretch' will stretch the image to fill the entire preview window. Default is 'image-fit'.
      ICON STYLE: 'icons-normal' or 'icons-perspective'. Affects the style of system icon used. 'icons-normal' will use a rectangular icon. 'icons-perspective' will use icons with a perspective effect applied. Default is 'icons-perspective'.
      The gamelist font features a folder icon in place of the # symbol. Name your folder with a preceding # symbol to display the folder icon. e.g '# folder'
      F 1 Reply Last reply Reply Quote 6
      • Stuart2773S
        Stuart2773
        @ruckage
        Thanks for sharing,
        BTW, the icon style does not display on the pi
        have you ever thought of adding icons for the Sega Pico ?
        ruckageR 2 Replies Last reply Reply Quote 2
        • ruckageR
          ruckage @Stuart2773
          @stuart2773
          Thanks for testing. That's strange I've just tested myself and the icons and grid backdrop image are both missing on the pi and I'm not sure why at the moment. That means the windows build and rpi build must be behaving slightly differently. I'll do some investigating and hopefully fix it today .
          • ruckageR
            ruckage @Stuart2773
            @stuart2773
            The bug has been fixed. It was an annoying one to track down. In the end it turned out to that ES on the rpi doesn't like the minus symbol (-) in variable names. Once I changed the variable name the theme then worked as expected. @jdrassa do you know if this a bug or just a difference between linux and windows?
            I've updated the download link in my original release post and will also add a link to the first post in this thread.
            Stuart2773S S 2 Replies Last reply Reply Quote 4
            • Stuart2773S
              Stuart2773 @ruckage
              @ruckage
              cheers, everything works perfect now.
              • KleenaxK
                Kleenax
                Finally got some time to put it on my pie, it looks amazing thank you for sharing.
                  SeraphTC @ruckage
                  @ruckage I'd love to check this out, but it looks like the download isn't working for some reason? The link is functional, but the file fails to download. Looks like a problem with mega. Any chance of a reup to a different host please?
                  • ruckageR
                    ruckage @SeraphTC
                    @SeraphTC
                    Not sure what happened with that file, strange. I've re-uploaded it and the link in the first post should now work.
                      SeraphTC @ruckage
                      @ruckage Works perfectly now, thank you!
                      Incidentally, thanks also for your nes and snes mini themes. They're fantastic. Is there any chance we might see a 'mega drive mini' style theme in the future?
                      Thanks for all your contributions!
                        GeekCritique
                        Love, love, LOVE this theme, thank you so much! Between this and mini-snes, I felt compelled to send a donation your way!
                        I just got my RetroPie connected to my CRT, and I'd love to see a 240p-compatible version of this! But like you said, I know it'd be a lot of work for very few users, so no worries either way!
                        Once again: THANK YOU!
                        ruckageR 1 Reply Last reply Reply Quote 1
                        • ruckageR
                          ruckage @GeekCritique
                          @GeekCritique said in Mega-Tech theme for Sega based builds:
                          :D thank you very much, I really appreciate that.
                          There may be a 240p version at some point. It should kind of work as it is but the main issues will be more due to the 4:3 aspect ratio rather than the resolution itself.
                          • quicksilverQ
                            quicksilver
                            This theme looks great! I actually grew up a Sega kid and didn't own a Nintendo system until the N64 so this theme really appeals to me. If only I trusted retroflag more I would probably buy their megadrive pi case and use this theme. I have been using your snes theme and have been teaching myself Photoshop to fill in the systems you haven't finished yet (for my own personal use of course). Though they aren't nearly is good as yours. Anyway, always look forward to what you come up with next! Great work man!
                            • H
                              hhromic
                              @ruckage interested on adding this theme to your GitHub so it can be added to RetroPie's esthemes system? :)
                                joharibk
                                I was looking at Super NT & really like the simple menu. I rearranged some stuff and delete all the icons on this theme to make something similar to the Super NT. I got stuck with line height & stuff and I don’t know the fonts that Super NT is using, maybe custom one?
                                This is where I am so far.
                                Anyone Know what font the Super NT use? Or something similar. 😅
                                • X
                                  xNYARLx
                                  Some addons: ScummVM
                                  • X
                                    xNYARLx
                                    And modified theme to disable logo on right side and center icon (when u have problem witch display logo on right side of screen):
                                    <theme>
                                    <formatVersion>6</formatVersion>
                                    <theme>
                                    <include>./config.xml</include>
                                    <view name="system, basic, detailed, video">
                                    	<helpsystem name="help">
                                    		<pos>2 2</pos>
                                    	</helpsystem>
                                    	<image name="background" extra="true">
                                    		<pos>0 0</pos>
                                    		<size>1 1</size>
                                    		<path>./art/background.png</path>
                                    		<color>ffffff</color>
                                    	</image>
                                    	<image name="overlay" extra="true">
                                    		<pos>0 0</pos>
                                    		<size>1 1</size>
                                    		<path>./art/overlay.png</path>
                                    		<color>ffffff77</color>
                                    		<zIndex>300</zIndex>
                                    	</image>
                                    	<text name="underline" extra="true">
                                    		<fontPath>./art/megatech_list_mono.ttf</fontPath>
                                    		<fontSize>0.0444444444444444</fontSize>
                                    		<size>0.3625 0.025</size>
                                    		<pos>0.046875 0.7166666666666667</pos>
                                    		<color>00c600</color>
                                    		<zIndex>200</zIndex>
                                    		<alignment>left</alignment>
                                    		<origin>0 0</origin>
                                    		<text>   </text>
                                    	</text>
                                    	<text name="help_text" extra="true">
                                    		<fontPath>./art/megatech_alt_mono.ttf</fontPath>
                                    		<size>1 0.0222222222222222</size>
                                    		<pos>0 0.9472222222222222</pos>
                                    		<color>c6c600</color>
                                    		<alignment>center</alignment>
                                    		<lineSpacing>1</lineSpacing>
                                    		<zIndex>350</zIndex>
                                    	</text>
                                    	<image name="window_backdrop" extra="true">
                                    		<size>0.5 0.6222222222222222</size>
                                    		<pos>0.471875 0.275</pos>
                                    		<zIndex>-200</zIndex>
                                    	</image>
                                    </view>
                                    <view name="system">
                                    		<path>./art/system_backdrop${iconstyle}.png</path>
                                    	</image>
                                    		<text>[select]=screensaver  [start]=menu  [x]=random  [a]=select</text>
                                    	</text>
                                    	<image name="logo">
                                    		<path>./art/logos/${region}/${system.theme}.png</path>
                                    	</image>
                                    	<text name="logoText">
                                    		<fontSize>0.06</fontSize>
                                    		<color>c60000</color>
                                    		<forceUppercase>true</forceUppercase>
                                    		<text>${system.fullName}</text>
                                    	</text>
                                    	<carousel name="systemcarousel">
                                    		<type>vertical</type>
                                    		<color>00000000</color>
                                    		<logoScale>1</logoScale>
                                    		<logoSize>0.3625 0.0555555555555556</logoSize>
                                    		<size>0.3625 0.4611111111111111</size>
                                    		<pos>0.046875 0.3111111111111111</pos>
                                    		<maxLogoCount>5</maxLogoCount>
                                    	</carousel>
                                    	<text name="systemInfo">
                                    		<backgroundColor>00000000</backgroundColor>
                                    		<size>0.2875 0.0305555555555556</size>
                                    		<pos>0.053125 0.8444444444444444</pos>
                                    		<alignment>right</alignment>
                                    		<zIndex>100</zIndex>
                                    	</text>
                                    	<image name="system_image" extra="true">
                                    		<path>./art/icons${iconstyle}/${region}/${system.theme}.png</path>
                                    		<size>0 0.2833333333333333</size>
                                    		<pos>0.721875 0.45</pos>
                                    		<origin>0.5 0</origin>
                                    	</image>
                                    	<image name="system_logo" extra="false">
                                    		<size>0.3625 0.0555555555555556</size>
                                    		<pos>0.540625 0.3194444444444444</pos>
                                    	</image>
                                    	<text name="info-label" extra="true">
                                    		<size>0.1 0.0305555555555556</size>
                                    		<pos>0.053125 0.8</pos>
                                    		<text> games</text>
                                    	</text>
                                    	<image name="info_mask" extra="true">
                                    		<size>0.1875 0</size>
                                    		<pos>0.153125 0.8444444444444444</pos>
                                    		<path>./art/info_mask.png</path>
                                    		<zIndex>110</zIndex>
                                    	</image>
                                    	<text name="message-text" extra="true">
                                    		<size>0.25 0.0944444444444444</size>
                                    		<pos>0.159375 0.7944444444444444</pos>
                                    		<text> Push (A) button &#10;to enter a system</text>
                                    		<zIndex>115</zIndex>
                                    	</text>
                                    </view>
                                    <view name="basic, detailed, video">
                                    		<path>./art/gamelist_backdrop.png</path>
                                    	</image>
                                    		<text>[select]=options  [start]=menu  [y]=favourites  [x]=random  [a]=select</text>
                                    	</text>
                                    	<image name="logo">
                                    		<pos>0.046875 0.3222222222222222</pos>
                                    	</image>
                                    	<textlist name="gamelist">
                                    		<forceUppercase>1</forceUppercase>
                                    		<scrollSound>./sounds/se_sys_cursor.wav</scrollSound>
                                    		<fontSize>0.0592592592592593</fontSize>
                                    		<primaryColor>00c600</primaryColor>
                                    		<secondaryColor>c6c600</secondaryColor>
                                    		<selectedColor>c60000</selectedColor>
                                    		<size>0.35 0.3111111111111111</size>
                                    		<pos>0.053125 0.3861111111111111</pos>
                                    		<horizontalMargin>0.0125</horizontalMargin>
                                    	</textlist>
                                    	<datetime name="md_releasedate">
                                    		<size>0.125 0.025</size>
                                    		<pos>0.265625 0.7388888888888889</pos>
                                    	</datetime>
                                    	<image name="date_mask" extra="true">
                                    		<path>./art/date_mask.png</path>
                                    		<size>0.359375 0.0277777777777778</size>
                                    		<pos>0.046875 0.7388888888888889</pos>
                                    		<color>000000</color>
                                    	</image>
                                    	<text name="md_publisher">
                                    		<size>0.263 0.025</size>
                                    		<pos>0.328125 0.7388888888888889</pos>
                                    		<origin>1 0</origin>
                                    	</text>
                                    	<text name="rating-label" extra="true">
                                    		<text>rating</text>
                                    	</text>
                                    	<rating name="md_rating">
                                    		<pos>0.0671875 0.8472222222222222</pos>
                                    		<size>0.0125 0.0222222222222222</size>
                                    		<filledPath>./art/rating_on.png</filledPath>
                                    		<unfilledPath>./art/rating_off.png</unfilledPath>
                                    	</rating>
                                    		<text> Push (A) button &#10;to start game</text>
                                    	</text>
                                    </view>
                                    </theme>
                                    • CrushC
                                      Crush @ruckage
                                      @ruckage said in Mega-Tech theme for Sega based builds:
                                      Thanks for the replies. I need to make a couple of small modifications before I can release but will do so soon.
                                      @linuxarcadeguy said in Mega-Tech theme for Sega based builds:
                                      @ruckage Please include a 5:4/4:3 version of the theme
                                      Not a simple task unfortunately, the theme is just not well suited to a 4:3 or 5:4 version so I would have to redesign pretty much the whole theme to fit those aspect ratios which is a lot of work and I'm not convinced it's worth the effort for the small number of people who would use them. If there is a lot of interest then maybe but certainly not when it's first released.
                                      Would it help if i send you my files of my 4:3 version of your theme? (It's a WIP)
                                      Original:
                                      4:3 version:
                                      • F
                                        FiKiBE @ruckage
                                        @ruckage Let's see if you are still around. Any chance you still have the mega-tech theme available? The ancient Mega-link is broken.
                                        Regards
                                        Filip
                                        CrushC 1 Reply Last reply Reply Quote 1
                                        • CrushC
                                          Crush @FiKiBE
                                          @FiKiBE the link is online.
