    Crackling Sound mame2003
    crackling soundmame2013 soundhdmi audio
    28 Posts 10 Posters 7.1k Views
      grant2258 Banned
      the less i say the better ive already been banned on the github page. I couldnt agree more ive never met such a discourteous attitude reminds me of people in london they have this exact superiority attitude. The further you get north from london the nicer the people are.
      • F
        fumanxu
        Hi guys, I'm experiencing the same problem with a pi0 and gpi case, the games executed through lr-mame2003 have crackling sound. In principle I though that it was a problem with the performance of pi0, but when I execute the same roms in lr-mame2000 the sound is perfect, and for compatibility issues, I want/need to use lr-mame2003 instead lr-mame2000.
        Any idea? maybe I need an extra config.
          dankcushions Global Moderator @fumanxu
          @fumanxu i think it's very possibly a performance issue. even if they are the same games, mame2003 includes 3 years of emulation improvements over mame2000, so they cpu requirements will be more. this is why we recommend mame4all for pi0/1: https://github.com/RetroPie/RetroPie-Setup/wiki/Arcade#step-1-choose-your-arcade-emulators
          • F
            fumanxu @dankcushions
            @dankcushions my problem with mame4all is that is not based on libreto so I cannot configure the buttons via retropie/retroarch. How can I configure manually the buttons of the gpi case (in fact, it is using xbox 360 controller driver).
              mitu Global Moderator @fumanxu
              @fumanxu You can configure it like any other MAME based emulators - you can use a keyboard and access the configuration menu of the emulator.
              • F
                fumanxu
                Hi @mitu
                My problem is that it's difficult to connect a keyboard in gpi case, so I was wondering if there is a way to configure via ssh the x360 controller in the mame4all config.
                  @fumanxu it is not, but if you are getting ok performance in lr-mame2000 you can continue using that. it's the same romset and should only perform marginally worse. maybe imperceptibly so.
                  • F
                    fumanxu
                    Yes, the problem with lr-mame2000 is that is not compatible with all games. :(
                    In any case I will try to configure the gpicase controller searching in the config files for mame4all
