    SENSIBLE overclock settings for B+ w/fan and heatsinks?
    overclock b+
    6 Posts 4 Posters 1.1k Views
    • V
      VictimRLSH
      Got my B+ working with case/heatsink/fan kit, but will want to overclock it. The Advanced tab under the Docs covers 0,1,2, and 3 overclocking, but not B+. I realize that each individual RPi is made with slightly different components and not every one overclocks the same, but I'm not trying to break any speed records, I just need parameters that will give a decent but reliable speed increase with heatsinks and a fan.
      There is probably a link around here for it, but searching just brings up the parameters for older boards.
      Edit: I did find some discussion on this, it seems the B+ is about as clocked up as you can make it at 1400mhz, so is it really not worth the effort to overclock a B+?
      System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
        crumbs
        The standard clock speed is 1.4GHz, I believe you should squeeze around 1.6GHz out of it if you push it.
        ETA Prime has a video on this:
          dankcushions Global Moderator
          i would say the sensible CPU overclock is "no overclock" :) there really isn't many emulation scenarios where it makes a difference. you need to be specific about what you're trying to achieve.
          • V
            VictimRLSH @dankcushions
            @dankcushions No specific goal in mind, just wanted to get what performance the appropriate hardware 'entitles' me to. I might try the 1.5ghz w/gpu overclock from the video. I appear to have adequate cooling and power supply.
            KN4THXK 1 Reply Last reply Reply Quote 0
            • KN4THXK
              KN4THX @VictimRLSH
              @victimrlsh I didn't overclock my pi 3B+ this time around as I didn't notice much difference and it is essentially an overclocked 3B with better cooling with that model. I did overclock the GPU which made a good difference.
              "If you're gonna play the Game Boy, You gotta learn to play it right" - https://www.youtube.com/watch?v=FYLGl92ETNQ
              • V
                VictimRLSH
                I've been running the 1500mhz profile from the video all night, temp on both CPU and GPU went from 35c to 39c, with a small but noticeable performance increase. I'll call that good for now.
