Questions on saving state with Xbox 360 controller
I'm attempting to save state on SNES with Xbox 360 controller. I've seen a few different hotkey assignments from the GitHub documentation and in various forums. So here are my questions:
- Is save state enabled by default on RetroPei?
- What Xbox 360 buttons should I be using to save state? I've been trying select + L1, select + L2 and select + Left D-Pad which leads to my next question...
- Is there any form of on-screen confirmation that the state was saved?
@sparecycle said in Questions on saving state with Xbox 360 controller:
such as? there's really only one thing that's worth reading - the official documentation :) https://github.com/RetroPie/RetroPie-Setup/wiki/RetroArch-Configuration#default-joypad-hotkeys
yes, if you use a libretro/retroarch emulator. lr-snes9x-next is one of those, and that's the default snes emulator, so...
see above link. that does presume you configured your controller correctly, mind.
yes. yellow text appears at the bottom.
