    Resolutions inconsistant between versions
    13 Posts 3 Posters 2.8k Views
      smoothmalik
      the setting in the config file for both versions are the same overscan scale is also set to 1.
        dankcushions Global Moderator
        i had the same thing. for whatever reason, pi2s and pi3s have different overscan, so you need to use different settings. you'll have to tweak your overscan settings until it looks right. here's what worked for me, although i guess it must vary depending on your tv:
        overscan_left=-8
        overscan_right=-8
        overscan_top=-24
        overscan_bottom=-24
        (and overscan scale set to 1 of course)
          smoothmalik
          i am unable to save the changes i make I get an error "Permission denied. Please contact your web hosting service provider for assistance."
          Im using an ftp client to edit
            i edit via the command line. do sudo nano /boot/config.txt
            you will probably be able to set your ftp client as a sudo user but how to do that will vary depending on the ftp client. can't help you there.
              smoothmalik
              the changes im making and saving are not being reflected when I run emulation station again or restart the whole retropie. Do I have to enable overscan somehow?
                dankcushions Global Moderator @smoothmalik
                @smoothmalik you have to restart the pi for them to work. paste your entire config.txt here and we can take a look.
                  smoothmalik
                  I started with your settings and fooled around with the numbers but nothing ever changed. I restarted a few times aswell no change. They are currently as you see reflected below.
                  # http://www.raspberrypi.org/documentation/configuration/config-txt.md
                  #hdmi_safe=1
                  #disable_overscan=1
                  #overscan_left=-8
                  #overscan_right=-8
                  #overscan_top=-24
                  #overscan_bottom=-24
                  # overscan.
                  #framebuffer_width=1280
                  #framebuffer_height=720
                  #hdmi_force_hotplug=1
                  #hdmi_group=1
                  #hdmi_mode=1
                  #hdmi_drive=2
                  # no display
                  #config_hdmi_boost=4
                  # uncomment for composite PAL
                  #sdtv_mode=2
                  #arm_freq=800
                  #dtparam=i2c_arm=on
                  #dtparam=i2s=on
                  #dtparam=spi=on
                  # Uncomment this to enable the lirc-rpi module
                  #dtoverlay=lirc-rpi
                  dtparam=audio=on
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=256
                  overscan_scale=1
                    please format your logs correctly: https://retropie.org.uk/forum/topic/3/read-this-first :)
                    but i can just about make out that your overscan settings are commented out. you need to remove the hashtags, as per what i posted above.
                      #overscan_left=-8
                      #overscan_right=-8
                      #overscan_top=-24
                      should be
                      overscan_left=-8
                      overscan_right=-8
                      overscan_top=-24
                      overscan_bottom=-24
                        smoothmalik
                        removing the hashtags worked like a charm thanks...
                          BuZz administrators @smoothmalik
                          @smoothmalik Please format your posts - I have fixed your post above. https://retropie.org.uk/forum/topic/3/read-this-first
