    PiGRRL 2 PiTFT help
    pigrrl 2
    2 Posts 2 Posters 559 Views
      smoenra
      Hello,
      I need some help with my 2.8 PiTFT resistive display with the PiGRRL 2 project. I've followed the instructions, imaged the SD card using Etcher for RetroPie, but when I do the command prompts below it hangs on Configuring PiTFT.... and I have to shut it down.
      cd
      sudo curl https://raw.githubusercontent.com/adafr ... ft-fbcp.sh >pitft-fbcp.sh
      sudo bash pitft-fbcp.sh
      No matter what I try, it will not go past this point and the screen stays white. I went as far as to manually download a driver for the screen, but after doing this I lost my HDMI to my TV for setup and everything was on the PiTFT, which was great as I could now see the RetroPie menu, but as soon as I went to a command prompt (F4) I would briefly see the output then it would just go white again. I've re-imaged the SD card multiple times, and the same result occurs each time. Any suggestions?
      Setup:
      Pi3
      2.8" PiTFT B+ resistive
      Thanks!
      • V
        VictimRLSH
        The Adafruit site has a troubleshooting guide, the white screen issue is addressed there.
        https://learn.adafruit.com/pigrrl-2?view=all#trouble-shooting
        System Config: Retropie 4.4 with full desktop, RPi 3B, 256gb SD, 5v 2.1A 5,200 mAH USB battery. EasyMSX controller mounted with Pimoroni Hyperpixel 4 (non touch). Also running 4.6 on a 4gb Pi 4 serving as my primary desktop computer now.
