    Yet another Xin-Mo Problem
    xin-mo
    2 Posts 1 Posters 457 Views
      Magnum77
      I got 2 single player Xin-Mo controllers.
      I tested to map all keys using emulationstation and both joysticks and all buttons work when selecting in Emulationstation.
      When going into a game the second controller does not work but all buttons works.
      I have tested the usbhid.quirks=0x16c0:0x05e1:0x040 in the cmdline that works when using the 2 player Xin-mo controller. However I am using 2 singleplayer boards as I thought they should be default be detected as 2 joysticks.
      https://retropie.org.uk/docs/Xin-Mo-Controller/
      I tested the the joysticks using the jtest /dev/input/js0 and js1. (Adding … to match the numbers so its easier to see)
      On js0 I get: Axes: 0:-32767 1:-32767 2: 0...…...3: 0.........4: 0 5: 0 Buttons: 0:0ff …. etc..
      On js1 I get: Axes: 0: 0...…...1: 0...…..2:-32767 3:-32767 4: 0 5: 0 Buttons: 0:0ff …. etc..
      Both register in the tests. From -32767 to +32767
      Another thing is that on js1 Buttons: 8:on and 9:on and goes to :off when I press them.
      I had this setup working on early 4.x version but where an idiot and did not do a backup.
      Any suggestions?
        Magnum77
        I guess what I wrote earlier showed the problem.
        Will hardcode the retroarch.cfg with correct axis values.
        P1
        UP=-3
        DOWN=+3
        LEFT= -2
        RIGHT=+2
        P2:
        UP=-1
        DOWN=+1
        LEFT= -0
        RIGHT=+0
