    NES won't work on out of box install of 4.4
    nes
    2 Posts 2 Posters 355 Views
      glimo
      Installed RetroPie stock image 4.4 on a pi2 on a brand new 32g sd card. Copied my Roms ZIP from my FCEUX folder on Windows -- all these roms work fine (it's the no-image set).
      Have tried all 3 NES emulators. Have tried the whole archive, or single files (both zipped and unzipped). No Roms will load.
      RunCommand.Log below:
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so --config /opt/retropie/configs/nes/retroarch.cfg
      "/home/pi/RetroPie/roms/nes/Legend of Zelda, The (USA).nes" --verbose --appendconfig /dev/shm/retroarch.cfg
      [INFO] RetroArch 1.7.5 (Git c9c6c5a)
      [INFO] Redirecting save file to "/home/pi/RetroPie/roms/nes/Legend of Zelda, The (USA).srm".
      [INFO] Redirecting savestate to "/home/pi/RetroPie/roms/nes/Legend of Zelda, The (USA).state".
      Capabilities: NEON VFPv3 VFPv4
      Built: Oct  9 2018
      [INFO] Version: 1.7.5
      [INFO] Git: c9c6c5a
      [INFO] Loading dynamic libretro core from: "/opt/retropie/libretrocores/lr-fceumm/fceumm_libretro.so"
      [INFO] [overrides] no core-specific overrides found at /home/pi/.config/retroarch/config/FCEUmm/FCEUmm.cfg.
      [INFO] [overrides] no content-dir-specific overrides found at /home/pi/.config/retroarch/config/FCEUmm/nes.cfg.
      [INFO] [overrides] no game-specific overrides found at /home/pi/.config/retroarch/config/FCEUmm/Legend of Zelda, The (USA).cfg.
      [INFO] Shaders: preset directory: /home/pi/.config/retroarch/shaders/presets
      [INFO] Shaders: no game-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/Legend of Zelda, The (USA).cgp.
      [INFO] Shaders: no game-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/Legend of Zelda, The (USA).glslp.
      [INFO] Shaders: no content-dir-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/nes.cgp.
      [INFO] Shaders: no content-dir-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/nes.glslp.
      [INFO] Shaders: no core-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/FCEUmm.cgp.
      [INFO] Shaders: no core-specific preset found at /home/pi/.config/retroarch/shaders/presets/FCEUmm/FCEUmm.glslp.
      [INFO] Environ SET_VARIABLES.
      [INFO] Environ SET_CONTROLLER_INFO.
      [INFO] Controller port: 1
      [INFO]    Auto (ID: 1)
      [INFO]    Gamepad (ID: 257)
      [INFO]    Zapper (ID: 258)
      [INFO] Controller port: 2
      [INFO]    Auto (ID: 1)
      [INFO]    Arkanoid (ID: 514)
      [INFO] Remaps: remap directory: /opt/retropie/configs/nes/
      [INFO] Remaps: no game-specific remap found at /opt/retropie/configs/nes/FCEUmm/Legend of Zelda, The (USA).rmp.
      [INFO] Remaps: no content-dir-specific remap found at /opt/retropie/configs/nes/FCEUmm/nes.rmp.
      [INFO] Remaps: no core-specific remap found at /opt/retropie/configs/nes/FCEUmm/FCEUmm.rmp.
      [INFO] Environ GET_LOG_INTERFACE.
      [INFO] Environ SET_SUPPORT_ACHIEVEMENTS: yes.
      [INFO] Environ SET_PIXEL_FORMAT: RGB565.
      [libretro INFO] Frontend supports RGB565 - will use that instead of XRGB1555.
      [INFO] Loading content file: /home/pi/RetroPie/roms/nes/Legend of Zelda, The (USA).nes.
      [INFO] Did not find a valid content patch.
      [INFO] CRC32: 0x3fe272fb .
      [INFO] Environ PERFORMANCE_LEVEL: 5.
      [INFO] Environ SET_INPUT_DESCRIPTORS:
      [INFO]  RetroPad, User 1, Button "B (bottom)" => "B"
      [INFO]  RetroPad, User 1, Button "Y (left)" => "Turbo B"
      [INFO]  RetroPad, User 1, Button "Select" => "Select"
      [INFO]  RetroPad, User 1, Button "Start" => "Start"
      [INFO]  RetroPad, User 1, Button "D-Pad Up" => "D-Pad Up"
      [INFO]  RetroPad, User 1, Button "D-Pad Down" => "D-Pad Down"
      [INFO]  RetroPad, User 1, Button "D-Pad Left" => "D-Pad Left"
      [INFO]  RetroPad, User 1, Button "D-Pad Right" => "D-Pad Right"
      [INFO]  RetroPad, User 1, Button "A (right)" => "A"
      [INFO]  RetroPad, User 1, Button "X (up)" => "Turbo A"
      [INFO]  RetroPad, User 1, Button "L" => "(FDS) Disk Side Change"
      [INFO]  RetroPad, User 1, Button "R" => "(FDS) Insert/Eject Disk"
      [INFO]  RetroPad, User 1, Button "R2" => "(VSSystem) Insert Coin"
      [INFO]  RetroPad, User 2, Button "B (bottom)" => "B"
      [INFO]  RetroPad, User 2, Button "Y (left)" => "Turbo B"
      [INFO]  RetroPad, User 2, Button "Select" => "Select"
      [INFO]  RetroPad, User 2, Button "Start" => "Start"
      [INFO]  RetroPad, User 2, Button "D-Pad Up" => "D-Pad Up"
      [INFO]  RetroPad, User 2, Button "D-Pad Down" => "D-Pad Down"
      [INFO]  RetroPad, User 2, Button "D-Pad Left" => "D-Pad Left"
      [INFO]  RetroPad, User 2, Button "D-Pad Right" => "D-Pad Right"
      [INFO]  RetroPad, User 2, Button "A (right)" => "A"
      [INFO]  RetroPad, User 2, Button "X (up)" => "Turbo A"
      [INFO]  RetroPad, User 3, Button "B (bottom)" => "B"
      [INFO]  RetroPad, User 3, Button "Y (left)" => "Turbo B"
      [INFO]  RetroPad, User 3, Button "Select" => "Select"
      [INFO]  RetroPad, User 3, Button "Start" => "Start"
      [INFO]  RetroPad, User 3, Button "D-Pad Up" => "D-Pad Up"
      [INFO]  RetroPad, User 3, Button "D-Pad Down" => "D-Pad Down"
      [INFO]  RetroPad, User 3, Button "D-Pad Left" => "D-Pad Left"
      [INFO]  RetroPad, User 3, Button "D-Pad Right" => "D-Pad Right"
      [INFO]  RetroPad, User 3, Button "A (right)" => "A"
      [INFO]  RetroPad, User 3, Button "X (up)" => "Turbo A"
      [INFO]  RetroPad, User 4, Button "B (bottom)" => "B"
      [INFO]  RetroPad, User 4, Button "Y (left)" => "Turbo B"
      [INFO]  RetroPad, User 4, Button "Select" => "Select"
      [INFO]  RetroPad, User 4, Button "Start" => "Start"
      [INFO]  RetroPad, User 4, Button "D-Pad Up" => "D-Pad Up"
      [INFO]  RetroPad, User 4, Button "D-Pad Down" => "D-Pad Down"
      [INFO]  RetroPad, User 4, Button "D-Pad Left" => "D-Pad Left"
      [INFO]  RetroPad, User 4, Button "D-Pad Right" => "D-Pad Right"
      [INFO]  RetroPad, User 4, Button "A (right)" => "A"
      [INFO]  RetroPad, User 4, Button "X (up)" => "Turbo A"
      [INFO] Environ SYSTEM_DIRECTORY: "/home/pi/RetroPie/BIOS".
      [libretro INFO] Loading /home/pi/RetroPie/roms/nes/Legend of Zelda, The (USA).nes...
      [libretro WARN] Missing header or invalid iNES format file!
      [libretro WARN] An error occurred while loading the file.
      [INFO] Environ SET_MESSAGE: ROM loading failed...
      [ERROR] Failed to load content.
      [INFO] Unloading game..
      [INFO] Unloading core..
      [INFO] Unloading core symbols..
      [INFO] Saved core options file to "/opt/retropie/configs/all/retroarch-core-options.cfg"
        BuZz administrators @glimo
        @glimo this is explained in the docs - https://retropie.org.uk/docs/Nintendo-Entertainment-System/
        You need ROMs with headers. Headerless ROMs will not work.
