    8bitdo FC30pro not working in emulators
    27 Posts 9 Posters 26.5k Views
      Duhjoker
      I have literally done every thing that this thread has suggested and some things a few other threads have suggested. The controller works fine in ES and works for the Nintendo emulator but nothing else.
        pimpmaul69 @Duhjoker
        @Duhjoker said in 8bitdo FC30pro not working in emulators:
        Are you using libretro emulators? When you pick a game you need to push the "0" button which is "button a" on the 8bitdo controlller to get into options. Then choose emulators that start with "lr-" example: "lr-snes9x-next"
          Duhjoker
          Ok the only "lr" emulator I'm using is the lr-fceumm which works fine with the controller. When SNESx9 was working it was playing fine with the controller too.
          I'm a lil confused about what happened today. For some reason after trying all the above I tried to update/install snesx9 and it did not give me a choice to use binary so I tried source and it said the appropriate files were missing. So I tried to uninstall it and got the same message.
          So now I started with a fresh Jessie install with Retropie and try again.
          Which drivers are we supposed to be using? The PS drivers knock out my wifi so I've been using Xbox drivers. I don't know any thing about the other two.
            Duhjoker
            Got the fresh install going and installed
            Lr-fceum ---------works
            PCSX rearmed-------not working
            Snexs9-----------working
            Osmose---------not working
            Mupen64-------not working
            Reicasreicast -----not working
            Only the NES and SNES controls are working
              TheGecko
              I can confirm this today - fresh install of Retropie, paired successfully with the FC30 Pro running 1.69 firmware. UDev script setup to run in background mode, Retropie runs off the controller fine. Tried using PCX, Neogeo and PC Engine emulators, no luck - the dpad works, but no buttons.
              I'll give firmware 1.68 a go, and I'll try out the adjusted button assignments from above.
                TheGecko
                OK - Firmware 1.68 installed, and everything appears to be working now. I had to remove the controller in the bluetooth menu, then re-pair it. Reboot of retropie, and it all appears good now.
                I also powered down/up the controller after the firmware downgrade, just to be sure.
                  BuZz administrators @Duhjoker
                  Why are my posts all in code squares ?
                  Because you used a four space indent which can be used for code blocks. http://commonmark.org/help/
