    pc/ps3 controller problem
    controllers
    5 Posts 3 Posters 761 Views
      C0ka
      hi, i purchased a controller (trust gxt 540) today and hooked it up to my retropie as fast as i could.
      only to find that the device wont show. so i took the "jstest" and found that on my js0 i had a xbox controller.
      i searched and read some guides. updated the retropie and xpad and xboxdrv.
      and now i am clueless and dont know if i should return the controller or what not. it is specified that the controller is for pc and ps3
        Please add the info requested in https://retropie.org.uk/forum/topic/3/read-this-first to your post.
        Your controller seems to have a switch to toggle it between Xinput/DirectInput, try setting it to Xinput and see if it gets detected. Uninstall the xboxdrv, if the controller is Xinput compatible then it should be detected and work only with the xpad driver.
          C0ka
          i got it working, had to go back too the store. the controller i got turned out defective, got a new one and life is good.
          • W
            w0hn0h @C0ka
            @c0ka how can I find this jtest?
            mituM 1 Reply Last reply Reply Quote -1
              mitu Global Moderator @w0hn0h
              @w0hn0h Please don't bump old topics - open your own new topic and describe your issue, adding the info asked in https://retropie.org.uk/forum/topic/3/read-this-first.
