    Player 2 controller not working
    controllersplayer 2
    27 Posts 4 Posters 4.5k Views
      jp
      @mitu said in Player 2 controller not working:
      restore the kernel version
      Can't remember running rpi-update but I did apt-get update upgrade etc. some stuff to begin with.
      Can I run sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel safely? And will it find the headers then? Sorry to bother you again, but I am a kernel(header)-noob.
        I think it should be fine - see also this post on the Raspberry Pi forums.
          jp
          IT'S ALIVE! Thank you @mitu! After running the mentioned command and rebooting I ran the retropie-setup again and updated the driver, which worked. Had to do some keymapping in the menu then and it's fixed now!
          Next step: make a good retropie backup image of this working setup, because there is no soft shutdown...
            mitu Global Moderator @jp
            @jp So now both controllers work ?
              jp @mitu
              @mitu yes. since I configured the usb first, the hardware joystick is seen as player 2. But that's okay!
                @jp You can re-order them using the Configuration Editor or the Retropie Joystick selection tool.
                Glad you got them working in the end.
                  jp
                  Thanks, I will upvote your posts! Don't know if it helps or not. Happy retro gaming!
