    Pigrrl help - Pitft
    adafruitpigrrl 2display
    1 Posts 1 Posters 392 Views
    • N
      NickP4
      Hi all,
      I'm relatively new to creating Pigrrls and I have hit a roadblock.
      I installed the Pitft and Keypress packages that were asked of me in https://learn.adafruit.com/pigrrl-2?view=all#software - this needed to be done so i can use the handheld screen. Well... After installing the package, I can no longer see it on either my tv or my handheld screen... My handheld screen is still just a plain white display, while my tv is assumingly not recognizing the small resolution that it was set to after the package installed.
      Some things to note - im using the Adafruit Pigrrl 2 kit located here - https://www.adafruit.com/product/3014 and im using a raspberry pi 3 as the board.
      Any tips on how to actually get any sort of display now that the resolution is too small? or is there a way to get the handheld screen to work?
      Thank you.
