    I need help with eduke32
    helpeduke32
    1 Posts 1 Posters 537 Views
      Cesarpuig
      Hi. I need help with Euke32.
      In Eduke32, when I leave the game after playing, I get the following error:
      *** Error in `/ opt / retropie / ports / eduke32 / eduke32 ': free (): invalid next size (fast): 0xx02510fb0 ***
      *** Error in `/ opt / retropie / ports / eduke32 / eduke32 ': free (): corrupted size vs. prev_size: 0xx02510fd0 ***
      It happens to me with both version 7077 and version 7136.
      The version of the game is the following:
      DUKE3D.GRP v1.5 (Atomic Edition)
      DUKE.RTS v1.0 / 1.1 / 1.3D / 1.4 / 1.5
      The system is Retropie 4.4.3 in Raspberry pi 3.
      This is the content of eduke32.log:
      *EDuke32 r (?)
      Built Oct 24 2018 19:25:47, GCC 6.3.0, 32-bit
      Application parameters: -j / home / pi / RetroPie / roms / ports / duke3d
      Using / home / pi / for game data
      Using / home / pi / RetroPie / roms / ports / duke3d / for game data
      Using /home/pi/.config/eduke32/ for game data
      Initializing SDL 2.0.8
      Using "x11" video driver
      Searching for game data ...
      Using "duke3d.grp" as main game data file.
      Compiling: GAME.CON (151190 bytes)
      Including: DEFS.CON (35992 bytes)
      Including: USER.CON (45482 bytes)
      GAME.CON: In actor `ORGANTIC ':
      GAME.CON: 3967: warning: found else 'with no if'.
      GAME.CON: In state `pigshootenemystate ':
      GAME.CON: 5890: warning: found else 'with no if'.
      Found 2 warning (s), 0 error (s).
      Script compiled in 43ms, 65684 bytes
      Initialized 96.0M cache
      RTS file "DUKE.RTS" loaded
      Initializing OSD ...
      0 joystick (s) found
      Executing "settings.cfg"
      Setting video mode 1024x768 (8-bpp fullscreen)
      Refresh rate: 60Hz
      Initializing music ...
      Initializing sound ... 64 voices, 2 channels, 16-bit 48000 Hz
      Sound hlminhal.voc (# 23) not found!
      Sound hlmexhal.voc (# 24) not found!
      Sound yes.voc (# 45) not found!
      Sound fan.voc (# 77) not found!
      Sound hover.voc (# 80) not found!
      Sound turrrm.voc (# 145) not found!
      Sound turrrg.voc (# 146) not found!
      Sound turrat.voc (# 147) not found!
      Sound b3atk01.voc (# 152) not found!
      Sound turrpn.voc (# 161) not found!
      Sound turrdy.voc (# 162) not found!
      Sound b3atk01.voc (# 176) not found!
      Sound vpiss2.voc (# 182) not found!
      Sound jacuzzi2.voc (# 322) not found!
      Sound joke.voc (# 397) not found!
      Cache time: 203ms
      Cache time: 7ms
      AMMO FOR PISTOL!
      AMMO FOR PISTOL!
      ARMOR
      AMMO FOR PISTOL!
      AMMO FOR PISTOL!
      AMMO FOR PISTOL!
      SHOTGUN
      LARGE MEDKIT: +30
      AMMO FOR PISTOL!
      SMALL MEDKIT: +10
      Wrote eduke32.cfg
      Wrote settings.cfg
      Game Saved
      Wrote eduke32.cfg
      Wrote settings.cfg
      current actor: 162 (1062)
      g_errorLineNum: 556, g_tw: 4
      Wrote eduke32.cfg
      Wrote settings.cfg
      Wrote eduke32.cfg
      Wrote settings.cfg*
      I would appreciate any help :)
