    Vodool A-038 does not connect Vodool A-038 не подключается retropie 4.4 raspberri pi3 b +
    controllers
    20 Posts 3 Posters 722 Views
      Ateist
      I bought a set of case and gamepads. I installed the connected keyboard. Everything works except for the Vodool A-038 gamepad. How to set up and make it work
      Купил комплект корпус и геймпады установил подключил клавиатуру все работает кроме геймпада марки Vodool A-038 как настроить и заставить работать
      • rbakerR
        rbaker @Ateist
        @Ateist said in Vodool A-038 не подключается:
        Hi, It's an English forum. You said:
        "I bought a set of case and gamepads. I installed the connected keyboard. Everything works except for the Vodool A-038 gamepad. How to set up and make it work"
        Пожалуйста, не размещайте запрос в службу поддержки без предварительного чтения и следования советам в https://retropie.org.uk/forum/topic/3/read-this-first
          Ateist @rbaker
          @rbaker I did not find a solution to the problem on the Vodool A-038 gamepad on the forum, so I created a new query. And since people come to the forum from Russia, I posted a request in 2 languages
          • rbakerR
            rbaker @Ateist
            @Ateist Пожалуйста, не размещайте запрос в службу поддержки без предварительного чтения и следования советам в https://retropie.org.uk/forum/topic/3/read-this-first
              Ateist @rbaker
              @rbaker I looked through all the settings for gamepads and found the ps3 and Xbox settings if there is a Vodool A-038 setting on the retropie raspberri pi3 b + I would be happy if you give the link
              mituM rbakerR 3 Replies Last reply Reply Quote 0
                mitu Global Moderator @Ateist
                @Ateist There isn't any specific link for your controller in the RetroPie's docs. What have you tried in order to make it work ? Did you follow the steps in the Docs ?
                  Ateist @mitu
                  @mitu Vodool A-038 does not connect via usb; there is only bluetooth in the kit after connecting the retropie does not see and does not respond to button presses. I tried to install the driver for ps3 since the pc is defined as an android / pc / ps3 gamepad, there are no results, so I am writing to your forum since I cannot solve the problem for three days
                  mituM rbakerR 2 Replies Last reply Reply Quote 0
                    @Ateist Did you paired the controller via Bluetooth with RetroPie first, before attempting to configure it in Emulationstation ? I think you should leave the controller in 'PC' mode, definitely not in Android mode.
                    • rbakerR
                      rbaker @Ateist
                      @Ateist I was referring to the information requested in this list to prevent wasted time - Power Supply for instance?:
                      If you have done the above steps please create a new topic and add the following relevant information so that we can help narrow down the cause of your issue. Please do not add a "me too" to an old topic, as the cause of your issue may be different. Make sure your topic title summarises the issue - do not use topic titles like "HELP ME".
                      Pi Model or other hardware: (B, B+, 2 B, 3, X86 PC etc..)
                      Power Supply used: (If using a Pi)
                      RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest):
                      Built From: (Pre made SD Image on RetroPie website, Berryboot, or on top of existing OS etc.. - please provide the filename of any image used)
                      USB Devices connected:
                      Controller used:
                      Error messages received:
                      How to replicate the problem:
                      • rbakerR
                        rbaker @Ateist
                        @Ateist Also, that product says "Supports Android 2.3 or above system, Linux system, and Windows 8/7/XP, like Android Phone (REQUIRE an OTG CABLE), PC, Tablet, Android TV Box, Raspberry Pi. The controller is not a Bluetooth device. It comes with a RF receiver that connects via USB, much better than Bluetooth."
                        • rbakerR
                          rbaker @Ateist
                          @Ateist Did you follow this guide from their website:
                          Power on your computer and insert the USB receiver. Power on the controller, the 1 (or 2) red led light, keep press the home button and it will change between 1 led and 2 led.
                          Now please press home button 5-10 seconds, and it will keep 1 led light no matter how many times you press home button, that means it has changed to PC mode.
                          Enter the game and set up controller, wait for several minutes if the controller has no response, or unplug the USB receiver and replug it.
                          Repeat "unplug the USB receiver and replug it" if the controller still has no response.
                          This suggests an unreliable controller in my opinion and one unlikely to work very easily with a pi.
                            Ateist @rbaker
                            @rbaker On pc, the gamepad works well.I connected exactly RF receiver powered 5v2a mode switching did not work out. I downloaded the image from your retropie 4.4 site or should I try an earlier version?
                            • rbakerR
                              rbaker @Ateist
                              @Ateist 2A is not sufficient to power a Pi properly. How do you know that the usb device is compatible with the os that Retropie is built on?
                              • rbakerR
                                rbaker @Ateist
                                @Ateist And what do you get when you run jstest? Type:
                                jstest /dev/input/js0
                                  Ateist @rbaker
                                  @rbaker jstest /dev/input/js0
                                  Driver version is 2.1.0.
                                  Joystick (ShanWan PC/PS3/Android) has 6 axes (X, Y, Z, Rz, Hat0X, Hat0Y)
                                  and 13 buttons (BtnA, BtnB, BtnC, BtnX, BtnY, BtnZ, BtnTL, BtnTR, BtnTL2, BtnTR2, BtnSelect, BtnStart, BtnMode).
                                  Joystick (Microsoft X-Box 360 pad) has 8 axes (X, Y, Z, Rx, Ry, Rz, Hat0X, Hat0Y)
                                  and 11 buttons (BtnA, BtnB, BtnX, BtnY, BtnTL, BtnTR, BtnSelect, BtnStart, BtnMode, BtnThumbL, BtnThumbR).
                                  Testing ... (interrupt to exit)
                                    @Ateist Your output shows 2 different devices - a ShanWan PS3 clone and a MS X-Box 360 gamepad. Did you installed the xboxdrv driver ? Remove it and re-try.
                                      Ateist @mitu
                                      pi@retropie:~ $ jstest /dev/input/js0
                                      jstest: No such file or directory
                                        @Ateist This means there's not connected controller to be detected.
                                          Ateist @mitu
                                          @mitu gamepad connected to raspberry
                                          This is my problem the system does not see the gamepad
                                            In order for the gamepad to be detected and configured by Emulationstation - and the other emulators - it must be detected as a gamepad by the OS. If the OS (Raspbian) doesn't see it as a gamepad, it means it's not compatible with Linux, so there's nothing to configure. I advise you to try another controller - if you bought this one specifically for RetroPie, then you should return it and get a better supported controller.
