    Bluetooth Audio
    bluetooth audio
    3 Posts 2 Posters 554 Views
      CaptainA178
      Is there a way to have Bluetooth Audio in Retropie 4.4? I've tried the Bluetooth option with no luck.
        Yes, it's possible, but you'll have to configure it manually - if you don't have the desktop installed. The BT configuration dialog is primarily meant for input devices, so it's not really tested for other types of devices.
          CaptainA178
          Alright, thank you for your help!
