    Skraper and general scraping problems
    scrapingskraper
    4 Posts 2 Posters 4.4k Views
      che_don_john
      Hi all,
      Like most of you, I've been having problem with the ES built-in scraper. First encountered issues a few months ago; updating ES seemed to resolve it for a while, but once again it's not working (tried it on some new Dreamcast roms) - neither updating ES or the RP scripts has fixed it.
      I then went to my second option, which is the Selphe Scraper - again, not matter which 'source' I choose, nothing is scraped. Third option was Syscraper - that worked on some of my Dreamcast roms but not others; and, I couldn't work out how to only scrape non-scraped ROMs.
      Finally I tried the Skraper Beta and it worked really well! Only problem is, I can't figure out how to make it so that it only scrape non-scraped roms; it just overwrites again and again, thus increasing the time it takes and undoign any fixes I've made manually.
      Does anyone know how I can tell Skraper to just scrape the non-scraped new roms?
      Cheers
        For Stephen Selph's scraper, there is an option to scrape only ROMs that have missing information, both in the GUI or on the command line (-append).
        As for Skraper or Skyscraper, there's no penalty in re-running the scraping over a full system, since both cache the resources locally and don't re-download it again from the online scraper.
        As a fail-safe method, leave only the ROMs needed in the folder/system you're trying to scrape and they'll be the only ones scraped. You can then copy back the rest of the ROMs and then merge the 2 gamelist.xml files produced for the 2 sets.
          che_don_john @mitu
          @mitu said in Skraper and general scraping problems:
          Thanks. Will try what you suggested with Skraper, but regarding Selph's scraper, none of the console sources seem to work.
          TheGamesDB.net is, I believe, the same one that the in-built ES scraper uses, so I guess that doesn't work for the same reasons discussed elsewhere. But are there any known issues with ScreenScraper.fr and OpenVGDB, or is it likely to be user error?!
            mitu Global Moderator @che_don_john
            @che_don_john Skyscraper can use TheGamesDB since it doesn't rely on the legacy API. I don't know if SScraper has that.
            I don't think there are any issues - in Skyscraper at least - with Screenscraper.fr or OpenVGDB.
            If you have specific examples - ROM names and checksums - where the entries are in the scraping site, but not found by Skyscraper, then please report them also in the Skyscraper topic.
