    Problem with 3d games
    problema
    5 Posts 4 Posters 251 Views
      Guibianche
      I've tried downloading psx and nintendo 64 games and they do not show up when I call my raspbarry
      I need help
      mituM 1 Reply Last reply Reply Quote -1
        mitu Global Moderator @Guibianche
        @Guibianche Please add more info as requested in https://retropie.org.uk/forum/topic/3/read-this-first.
        They do not show up .. where ? In the game list in Emulationstation ?
        • thelostsoulT
          thelostsoul
          The guy above me, follow his link and add the missing information, so we can help better. N64 games are problematic and only a handful of them are working. Sometimes you have to find the right settings to play it. If you are new to RetroPie, then I would first do the other things and come back to N64 later. Do you have older systems working? You say "problem with 3d games", as if 2D games aren't problematic.
          📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
            Guibianche @mitu
            @mitu he does not appear in emulationstation
            • quicksilverQ
              quicksilver @Guibianche
              @Guibianche check that your roms have supported extensions. If they are zipped you will need to unzip them. N64 supports .N64, .z64, .v64. Psx supports .Img, .iso, and .bin (with .cue)
