    Sega CD and PC Engine CD from an external usb pen drive using easy hax method
    sega cdpc engine cdnot workingexternal drivependrive
    28 Posts 3 Posters 4.6k Views
    • zefolhadelaZ
      zefolhadela @zefolhadela
      @mitu how can i go back to the original configuration, just unplug pendrive, restart system, and copy the stuff to the original location?
      • lostlessL
        lostless @zefolhadela
        @zefolhadela if something is not loading, the file is corrupt. There is no way to recover the data
        zefolhadelaZ 2 Replies Last reply Reply Quote 0
        • zefolhadelaZ
          zefolhadela @lostless
          @lostless sure just random games, from psx. i think this only damage some psx games.
          • zefolhadelaZ
            @lostless can i put you just a simple question? some of my psx game got currupted and i cant eeven load them, but all roms (most zip files) are running.. my question is can some roms be currupted but still running? (i was playing sonic hedgedog on genesis and i notice some frame drops randomly, so i start suspecting i need to replace all my games, in other words, nightmare for me .sbolded text
            • lostlessL
              @zefolhadela If a game is running, it is not corrupt. I never notice frame drops on sega genesis games. Thats a different issue not related to the memory card.
              zefolhadelaZ 1 Reply Last reply Reply Quote 0
              • zefolhadelaZ
                @lostless much thanks for the anwser man. is good to know that i dont need to replace all roms. i need to check that, maybe is the crt config (which makes pi run at 240p) but pretty sure is not about that
                • lostlessL
                  @zefolhadela If you are using any type of additional video filters, you my notice few frames dropped. The PI not very graphically strong. The only filter i use is the built in bilinear filter in retroarch, which doesn't take any cpu resources.
                  • zefolhadelaZ
                    @lostless nahh, im not using filters i am aware of that, i have my pi hooked up to a crt direcly, i just have my boot config modified, so i have menus ate 480p and that switch for game to 240p. something like this https://retropie.org.uk/forum/topic/8476/retropie-240p-15-khz-rgb-scart-tv-guide/2
