[Solved] help for retropie on top of ubuntu 18.04, usb mounted twice
Hello,
First sorry for my english because I'm french.
I have installed retropie with the retropie_setup.sh script inside ubuntu 18.04 on an old eeepc 701. But now, usb drives are mounted twice : one time as user on /media/user/"label_of_the_key" and a second time as root on /media/usb0 (to eject the drive, I have to enter my password)
I suspect retropie (and the package usbmount) to be responsible for that.
Can somebody tell me if it is a normal behaviour after having installed retropie and, if it isn't, how to fix it ?Thanks a lot
@antoine8168 Uninstall or disable the
usbmount
package from the RetroPie-Setup script. -
@mitu Thank you, uninstall usbromservice in retropie setup removed the usbmount package. My problem is solved.
