    ADVMAME not showing Frames Per Second
    advmame .94retropie 4.4
    4 Posts 2 Posters 559 Views
    • W
      wiggy808
      Pi Model: 3 Model B+
      RetroPie Version Used: 4.9.80-v7
      Built From: SD Image
      USB Devices connected: Standard USB keyboard, Logitech USB Gamepad
      Controller used: Logitech USB Gamepad
      Error messages received: N/A
      Guide used: https://github.com/retropie/retropie-setup/wiki/MAME#advancemame-094
      File: n/a
      Emulator: AdvanceMAME 0.94
      Attachment of config files: n/a
      How to replicate the problem: setup basic install of retropie and install AdvanceMAME 0.94
      So per the documentation F11 gives you FPS. Mine however gives some sort of percentage (cpu perhaps?).
      When I hit F11 it shows this in the upper right hand:
      auto 100% - 100%
      Both percentages change as I play, but I'm unsure of what they mean and how to translate them to FPS. How do I translate these into FPS or show FPS?
        Try using the current advmame (3.x), instead of the older version - F11 should work there.
        • W
          wiggy808
          Thanks!
          I know advmame 1.4 uses Romset .106, but to clarify what romset do 0.94 and 3.x use?
            Advmame 3 uses the same ROM set (0.106), advmame-0.94 uses an older one (0.94). See https://retropie.org.uk/docs/MAME/.
