    Help! I changes pcsx to analog sticks and now roms wont load
    roms wont load
    4 Posts 2 Posters 326 Views
    • N
      NoobishPi
      As you can tell from my name I am very noobish at Pi when I changed it to analog sticks the roms stoped loading I checked the roms folder and only .bin files were there no .cue for all games please someone help?
        Please add more info about your system https://retropie.org.uk/forum/topic/3/read-this-first.
        How did you change to analog sticks ? Can't you just change it back ?
        • N
          NoobishPi
          I used the in emulater pcsx analog stick changer now I cant change it back
            mitu Global Moderator @NoobishPi
            @NoobishPi Try renaming the configuration file - https://retropie.org.uk/docs/Playstation-1/#pcsx-rearmed-controls.
