    Static /dev/input entry for bluetooth controllers
    ps3 controllersdeviceretropiedynamic
    1 Posts 1 Posters 601 Views
      jmbooth2000
      It was bugging that depending on what USB devices were installed my bluetooth PS3 controllers would get a different /dev/input/event<n> assignment. The joystick selection script helps but didn't seem to be the right way to handle the problem and didn't work very well with some of the emulators.
      What I created instead was a way to use a udev rule to create a static ps3_controller_event1 link to whatever /dev/input/event<n> was assigned. This way I can pick exactly what controller I want to use and don't have to worry about the order. This technique also works with other controller types.
      I did a pile of research and didn't find any existing solutions. The closest I found were a couple of entries that said it wasn't possible. The following are my instruction on how to do this.
      First create a new udev rule using the following,
      sudo nano /etc/udev/rules.d/99-xxx_map_controllers.rules
      containing the following,
      ATTRS{name}=="PLAYSTATION(R)3 Controller", PROGRAM="/bin/ps3_dev_namer %k", SYMLINK+="%c"
      The first part of this looks for a udev assignment that matches ATTRS{name}=="PLAYSTATION(R)3 Controller". This occurs whenever your connect a PS3 controller. If you aren’t using ps3 controllers you can modify this to search for your controller identity by using the “udevadm info -a -n /dev/input/event1” command and finding the corresponding string for your controller.
      The second part defines the actions that should be taken when a PS3 controller is attached. In this case the PROGRAM="/bin/ps3_dev_namer %k” section calls the /dev/ps3_dev_namer script I created. This script iterates through the potential /dev/input/ps3_controller_event<n> devices and returns the first unassigned device. So on the first call it will return /dev/input/ps3_controller_event1. The SYMLINK+="%c" section creates a “/dev/input/ps3_controller_event1” entry that links to whatever /dev/input/event<n> was assigned to the first PS3 controller that was connected. Connecting the next PS3 controller will create a “/dev/input/ps3_controller_event2” entry that points to its appropriate event. This means that you can use the /dev/input/ps3_controller_event<n> entries you can use in your emulator config files.
      #!/bin/bash
      # /bin/ps3_dev_namer script to provide a static name for ps3 controllers
      # Created by Jonathan Booth ©2018 free for use providing this line remains
      # Called by udev rule to create static device entries that link to the dynamically /dev/input/event<n>
      # This  is useful when the device order changes but you need a static way to refer to the same device
      # I use this is retropie to create a static mapping for my ps3 controller events and joysticks
      # To use this script create “/etc/udev/rules.d/99-xxx_map_controllers.rules” with the following line
      # less the leading ‘#” character
      # ATTRS{name}=="PLAYSTATION(R)3 Controller", PROGRAM="/bin/device_namer %k", SYMLINK+="%c"
      BASENAME="/dev/input/ps3_controller"	# Change if you have a different controller
      COUNT=1
      if [[ $1 == js* ]]			# if we have a js<n> device
      then
              TYPE="_js"			# Append “_js”
      elif [[ $1 == event* ]]		# else if we have an event<n> device
      then
              TYPE="_event"		# Append “_event”
      fi
      while [ $COUNT -le 100 ]                # Main loop with backup plan to exit after 100 trys.
      do
              NAME="$BASENAME$COUNT$TYPE"     # Build filename to test for
              if [ -e $NAME ]                 	# if the file exists
              then
                      ((COUNT+=1))            	# increment count and try the next possible entry
              else                            		# file does not exist
                      echo $NAME | cut -c 6-  # output the name of the first available link less the "\dev" prefix
                      break                   	# break the loop and exit
              fi
      done
      I was pretty happy when I got this working as the combination of a keyboard, trackpad, trackball, 2 arcade controllers, 2 wii controllers, 2 old style usb controllers, and 2 PS3 controllers was driving me nuts every time I changed the order. Now I can create rules to create static named /dev/input devices that point to whatever the assigned /dev/input/event was.
      I hope this will be of use to others and I hope people will update this thread on how they use it.
