    [SOLVED] Problem with lr-bluemsx
    lr-bluemsx
    5 Posts 2 Posters 1.7k Views
    • saccublendaS
      saccublenda
      Hello, I have some problems running MSX games with lr-bluemsx. When I try to launch a game I get bounced back to ES, and runcommand.loggives this message:
      bash: /opt/retropie/supplementary/joystick-selection/js-onstart.sh: No such file or directory
      Parameters:
      Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-bluemsx/bluemsx_libretro.so --config /opt/retropie/configs/msx/r$
      /opt/retropie/supplementary/runcommand/runcommand.sh: line 1007:  4887 Segmentation fault      /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retrop$
      The emulator works fine with ColecoVision games, with the coleco.rom bios in /home/pi/RetroPie/BIOS/Machines/COL - ColecoVision. For the MSX I have the bios files MSX.rom, MSXDOS2.rom, MSX2.rom, MSX2P.rom, MSX2PEXT.rom and MSX2EXT.rom in /home/pi/RetroPie/BIOS/Machines/Shared Roms.
      I add that the same games run fine in lr-fmsx with the same bios files in /home/pi/RetroPie/BIOS and the capital .ROM extension.
      Any thoughts?
      Pi Model or other hardware: 3
      Power Supply used: USB3.0
      RetroPie Version Used: 4.4.8
      USB Devices connected: 1x Keyboard / 1x Controller
      Controller used: 8bitdo sfc30 (bluetooth)
        @saccublenda said in Problem with lr-bluemsx:
        Can you try to enable verbose logging in the Runcommand launch menu, then upload the (runcommand.log) to pastebin.com ?
        Note that BlueMSX requires some additional files - besides the BIOS files - as outlined in the Docs for the core.
        saccublendaS 1 Reply Last reply Reply Quote 0
        • saccublendaS
          saccublenda @mitu
          @mitu said in Problem with lr-bluemsx:
          If you refer to Database and Machines folders they are already in the BIOS directory. The verbose output of runcommand can be found in https://pastebin.com/rgY3VNQv.
            I think you're missing some of the BIOS files (in one of those folders). I installed lr-bluemsx, then followed the instructions in the docs link posted above - copied the 2 folders in the BIOS folder (overwriting everything) - and started the game, it just worked without issues.
            • saccublendaS
              saccublenda
              As a matter of fact there are 93 bios files spread in the Machines directory. I'm not sure which are needed, but overwriting the whole directory solved the problem.
              Thanks.
