    problems with the Samsung Monitor hdmi video signal
    black screen
    2 Posts 2 Posters 113 Views
      brunozero
      I have a samsung monitor P2470H, for some reason my raspberry 3B + does not signal the video when connecting to this monitor, the connection is via HDMI, the tv works normally, please if anyone knows how to help I am eternally grateful, about this...
      follows the manual of the monitor, has a table with the resolution that it supports:
      http://downloadcenter.samsung.com/content/UM/200910/20091008104107796/BN59-00841H-02Eng.pdf
        Does your monitor's HDMI port works ? Can you connect it to another device to see if it receives and displays HDMI video ?
        Try playing with the config_hdmi_boostconfiguration parameter in the config.txt file. From Video options in config.txt:
        config_hdmi_boost
        Configures the signal strength of the HDMI interface. The default value is 0 and the maximum is 11.
        The default value for the original Model B and A is 2. The default value for the Model B+ and all later models is 5.
        If you are seeing HDMI issues (speckling, interference) then try 7. Very long HDMI cables may need up to 11, but values this high should not be used unless absolutely necessary.
