    TG16/PC Engine Compatibility
    26 Posts 8 Posters 11.6k Views
      dedbob @ProxyCell
      @proxycell Did you ever happen to get Loom working? I'm having the same issue where it just goes to a black screen, though other TG16CD games are working fine.
      • ProxyCellP
        ProxyCell
        no, sadly - I'm guessing it is an upstream emulator issue and not related to retropie directly
        RPi3b+ - No overclock
        RetroPie - latest from Github, as always
        2x SF30 Pro 8Bitdo controllers
        • InsecureSpikeI
          InsecureSpike
          loom working for me guys
          RPi 3 - RetroPie + 500gb HDD [consoles] + Razer Onza Tournament
          RPi 3 - RetroPie + 32gb USB [computers] + Keyboard
          both with AttractMode + FuzzBoxx Layout
            dedbob @InsecureSpike
            @insecurespike Can you post a checksum or something similar for your working copy? I've managed to dig up 3 different images so far and all exhibit the same issue.
              dedbob
              On the topic of checksums, I did some more digging and found this forum post which set the gears turning:
              https://www.epforums.org/showthread.php?107785-PC-Engine-CD-Turbo-Duo-TurboGrafx-CD-Raspberry-Pi-Zero&p=1877571#post1877571
              I compared the checksum on my syscard3.pce to the ones listed on the github wiki, and sure enough, found that my file matched the "TurboGrafx CD Super System Card (USA) (v3.0).pce" file, and not the syscard3.pce file. Downloaded the one with the correct checksum, and Loom started right up!
              • DarksaviorD
                Darksavior @dedbob
                @dedbob I forgot I posted that there, heh.
