ow to restore settings of a specific system?
Hi there, I did a mess with two core (the gameboy and the playstation). With the result that gameby doens't have audio and playstation not loading any game. Wht I want to do is torestore the setting speciic only fr thiss two systems.
Can you help me? Thanks
What exactly did you change ? Can't you just change back to the previous settings ?
I don't remember exactley but I remember I was "playing" with the drivers of the game boy and now doesn't give sound. Then both in gameboy and playstation core I went on the retroarch menu and clicked on "restore default settings". game boy still doesn't have sound plus the retroarch menu has changed in a different frontend (not the black one with green menu voices, now is blue very similar to the playstation 3 os). The playstation can't lauunch the games.
I have an issue sometimes happen to me about the audio, and if I restore the settings for the entire retrorch I am scared to bring back that issue, so I just would like to restoregameboy and playstation
@Tackskull Remove the
retroarch.cfg
file for each system, then reinstall the emulators for them -lr-pcsx_rearmed
and ... whatever is the emulator for gba (lr-gambatte
Ok, where are this retroarch.cfg files? I am using both pcsx reamer and beetle-psx, don't remember wich gameboy emulator, but seems not connected to thesingle emulator but to the entire system core -
@Tackskull The configuration files for the systems are in
/opt/retropie/configs/<system_name>
, so check out- /opt/retropie/configs/psx
- /opt/retropie/configs/gba
