    Script to Mirror SD Card to USB Stick?
    scriptretropieusb stick
    2 Posts 2 Posters 411 Views
    • George SpiggottG
      George Spiggott
      Currently RetroPie automatically copies files (roms and configs) from a USB stick to the Pi. Is it possible to disable this process so that it happens on command rather than automatically?
      Also is it possible to reverse the process so that the USB stick can be used to mirror the contents of the Pi, or at least select folders from it, either automatically or ideally on command?
      Currently running:
      Retropie 4.8.9 on a Pi Zero 2W (Overclock Settings: CPU 1400Mhz)
      ES-DE on a GMKtec K6 (Windows 11, 32GB RAM)
      mituM 1 Reply Last reply Reply Quote 1
        mitu Global Moderator @George Spiggott
        @George-Spiggott said in Script to Mirror SD Card to USB Stick?:
        Yes, disable the usbmount service and the synchronization will not happen automatically.
        Yes, it's possible, but there's no provision in the RetroPie scripts for this kind of scenario.
        When you want to keep your ROMs on an external drive, you create a retropie-mount folder on it and RetroPie would sync the ROMs from the SDCard to the disc, then it will mount the disc so you can use it.
        If dont' want to use the external disc for the ROMs, but just synch to it, then you'll have to create a script to do it. Both synchronization methods (USB to card and vice-versa) use the rsync command, you can easily create 2 scripts to do this synchronization and add them under the retropiemenu system so you can call them directly from Emulationstation.
