SNES PROBLEM PLEASE HELP!
I cant play snes games they keep doing random things like I have to press select instead of start to play mario allstars only I cant play it anyway because once I get to the game its just a wall of different coloured pixels with a mario remis playing and in home alone 2 he just runs backwards into the guy your trying to run away from Ive tried uninstalling all the games and reinstalling them but it doesnt work I dont want to reset my pi what can I do to fix it? please help me I have no idea what could be wrong I did nothing
PLEEEEEEEEEEEEEEEEEEEEASE!
I NEEEEEEEEEEEEEEEEEED ME SOME MARIO
I haven't tried playing this myself, but I know there are issues with the game as explained here:
https://github.com/RetroPie/RetroPie-Setup/wiki/FAQ#does-super-mario-all-stars-work
ok well thankyou heaps for your help :) I'm not entirely sure how to do that do you know how I copy the code into the file or whatever you call it I cant even open it
@defazfuq Please just post a question and remain patient - other users and developers will help you if/when they can. There is no need to make further posts in CAPS and if anything is likely to get you ignored (and downvoted).
SORRY I'LL STOP NOW
This could be a multiple of different things , lets start at the beginning
ROMS - This is a sensitive issue due to rules but there are good and bad roms so please check the roms you are getting, Fish about the internet for more information.
Emulation - Which SNES emulator are you using , this maybe an issue based on your controller configuration my recommendation if your fairly new to this is look at lr-snes9x-Next , It's a solid emulator and uses retro arch configuration
My opinion would be this is a ROM issue from my experience, Which is limited to about 2 months of doing this.
does this mean the rom messed everything up and it will fix itself in 2 months time?
as long as I dont play that rom again? -
ps I dont know how to change my emulator?
Ok so that's fairly simple , start a game any game and when the black screen comes up just before the game press A, and change the emulator to the one you want, don't panic I was in the same place as you a month ago.
PROBLEM SOLVED NOW I CAN PLAY ME SOME MARIO THANKS :)
