    [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie
    gamelistscrapersoftware
    250 Posts 24 Posters 160.8k Views
    • nexusone13N
      nexusone13 @BadFurDay
      @badfurday is \\retropie\roms\scummvm accessible with Windows explorer ?
      ARRM (Roms Manager, Scraper for Recalbox, Batocera, Retropie, ES...) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
      Discord: https://discord.gg/p7QsBTS
      BadFurDayB 1 Reply Last reply Reply Quote 0
      • BadFurDayB
        BadFurDay @nexusone13
        @nexusone13 it is and can read/write ok. Checked folder/file permissions with Filezilla and it is set to 777. I don't think it has anything to do with your software tbh, just wondered if you had it happen before.
        nexusone13N 1 Reply Last reply Reply Quote 0
        • nexusone13N
          @badfurday I know that latest windows upgrade causes connection problems on SMB shares. There are discussions about this on the internet. But since you access it normally via the file explorer, I don't see where the problem can come from. sorry
          • mituM mitu referenced this topic on
          • nexusone13N
            nexusone13 @nexusone13
            Hi everyone,
            A new version of ARRM is available :
            1.9.1.1 (02/12/2022)
            • Memory optimization on Launchbox to avoid crashes due to lack of memory.
            • Addition of IGDB.com scrape engine. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-igdb-en
            • Addition: it is now possible to delete artwork/media tags in the replacement module
            • Addition of an 'Update' tab, allowing to update the LaunchBox database, SteamDB as well as the configuration files. See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=settings-en#update
            • Addition of a 'Provider Custom' checkbox in the 'Gamelist TAGs' tab which allows via a file %appdata%\Nexouille Soft\arrm\Database\provider_custom.txt to add tags/information automatically in the provider section of gamelist.xml . See wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=customize_provider_gamelist_en
            • Addition of help links (?) leading to dedicated sections of the Wiki
            • Moved the 'Delete unused images and videos' button to the 'Tools' tab
            • Moved 'Unused Overlays' button to 'Tools' tab
            • Fixed a bug that copied '-extra1' images in the 'wheels' directory instead of 'extra1' when 4 images mode was not activated.
            • Fixed a bug that sometimes scraping on HFSDB would cause ARRM to freeze.
            • Fixed a bug that prevented scrapers other than Screenscraper from downloading the video if fanart was not checked
            • Correction: Addition of an LF (line feed), if not present, when adding Roms in collections files (detected by Soaresden)
            • Fixed: Export to Attract Mode now takes the name of the Attractmode system as Emulator and no longer the name of the ARRM system folder (Bug detected by BadFurDay on Retropie Forum)
            • Fixed: Export to Attract Mode no longer takes into account hidden Roms (not managed by AttractMode)
            Donwload links:
            Full version via arrm_setup.exe (remember to uninstall the previous version): http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
            Full version without using arrm_setup.exe. (Allows you to install or update the application by copying files): http://jujuvincebros.fr/telechargements2/category/12-arrm-executable-only
            Changelog : http://jujuvincebros.fr/wiki/arrm/doku.php?id=changelog-en
            Beta versions page: http://jujuvincebros.fr/telechargements2/category/11-arrm-update-correctif
            ARRM WIKI: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=Start-en
            Videos tutorial playlist: https://www.youtube.com/playlist?list=PLwA4JmSgv-PtLlzwPMOad5Ti96UfsbSzK
            Keep in touch : http://jujuvincebros.fr/wiki/arrm/doku.php?id=contact-en
            Discord ARRM: https://discord.gg/p7QsBTS
            Donations : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=donations-en
            nexusone13N 1 Reply Last reply Reply Quote 1
            • nexusone13N
              Hello @mitu ,
              I have a question about the behavior of Retropie.
              When a rom file exists on the sd card but is not referenced in the gamelist.xml, will Retropie still display it in emulationstation or can it be told to display only those present in the gamelist.xml?
              This is related to the fact that the EmulationStation handles the <hidden> tag badly or not.
              Thanks in advance
                mitu Global Moderator @nexusone13
                @nexusone13 said in [SOFT] ARRM : Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie:
                By default, if a ROM is found and matches the system's list of extensions, it will be displayed. There is a configuration setting in EmulationStation (I'm sure there's also present in the versions used by Recalbox/Batocera) that disables this and instructs EmulationStation to read only the entries present in the gamelists (without checking if the file exists).
                The hidden tag is working fine, as far as I know. What do you mean by 'handles badly' ?
                • nexusone13N
                  nexusone13 @mitu
                  @mitu It's related to .M3U files.
                  In ARRM I added a feature to automatically create M3Us and put in <hidden> in the gamelist.xml the files indicated in the M3U. One of my users told me that the <hidden> didn't work on Retropie and gave me this link:
                  https://retropie.org.uk/forum/topic/32385/hiding-files-where-m3u-is-used.
                  I then understood that <hidden> was not recognized
                    That's not how the hidden tag works in EmulationStation - or at least in RetroPie's fork. The games with hidden tag are really hidden only in Kiosk mode, not in regular operation mode. Similarly, games with the kidmode kidgame tag are the only ones shown in Child mode.
                    nexusone13N 1 Reply Last reply Reply Quote 2
                    • nexusone13N
                      nexusone13 @mitu
                      thank you @mitu for this clarification
                      • nexusone13N
                        Hi everyone,
                        A new version of ARRM is available:
                        1.9.1.2 (03/19/2022)
                        • Added: If the boxbacks recovered on Screenscraper are less than 4 KB they are considered as blank and not recovered. To avoid green empty boxbacks.
                        • Added: 'Enable cache' checkbox in the 'Main options' tab, which allows textual information retrieved during a Scrape to be stored in a cache. Can be used for example following a crash during a scrape or a lack of gamelist. See Wiki: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=howto_cache_en
                        • Added: 'Load from Cache' button to retrieve cache information kept during previous scrapes for selected Roms and selected system.
                        • Added: 'Cache' button to cache already scraped selected elements.
                        • Added: 'Compress databases' button in the 'Tools' tab, which allows to compress the size of the databases used by ARRM. Automatically launches every 20 ARRM launches.
                        • Added: A checkbox: 'ROM Country Priority' in the 'Scrape Options' tab and in the media allocation forms. Allows to take in priority the artworks of the country indicated in parentheses in the name of the ROM file (screenscraper and launchbox). Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=media-assignation-en#order_of_priority_of_the_media_according_to_the_country
                        • Added: an 'Ignore existing MD5' checkbox in the 'Scrape Options' tab, which allows, when scraping on Screenscraper, to ignore the MD5 that already exists in the gamelist / Roms information panel
                        • Added: 'Arcade to Database' button in 'Update' tab: Used to update via .dat / .xml files the database used in 'Rename with Dat' or 'Arcade Clone Filter'. See Wiki: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=rename_game_with_datfiles_en#update_arcade_database_with_new_datfiles_dat_xml
                        • Added: Date/time variables usable in provider_custom.txt: %yyyy% (year), %dd% (day), %MM% (month), %HH% (hour 24), %mm% (minute) Wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=customize_provider_gamelist_en
                        • Added: 'Cartridge' checkbox in the 'Filter' tab
                        • Added: Change from 10 layers to 15 layers for templates
                        • Added: A Philips CDI template by RustyMG
                        • Modification: Button 'Create M3U' which makes it possible to create the M3U automatically for all or part of the selected roms. ARRM will search for files containing (dis*) (side*) (tape*) (part*) [part*]. Unique files are ignored. scrape information will be retained. Roms added in M3Us will have the attribute hidden in the gamelist.
                        • Modification: It is possible to indicate a local file with full path in the layers of the templates: see wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=create_template-en#definition_of_layers
                        • Modification: It is possible to add other information for the customization of sub-folders with image and description. see wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=custom_subfolder_en#new_format
                        • Modification: To avoid overloading the HFSDB server, searches are carried out in priority on the MD5 (if existing), then the name of the file, then the name of the game. For HFSDB, it is advisable to check 'Force MD5 before scraper' in the 'Scrape Options' tab if the MD5s do not exist.
                        • Modification: 'Rename with DAT' button: If the processed system is one of the Arcade systems declared in the %appdata%\Nexouille Soft\arrm\Database\arcade_systems_list.txt file, the search will first be done on the file name which in Arcade is normalized and the result will be very reliable, otherwise if the previous search does not return anything, the search will be done as before via MD5 / CRC32.
                        • Modification: Support for other .dat / .xml file formats for 'Arcade to Database' and 'Rename with Dat' procedures. Sample .dat and .xml files can be found in %appdata%\Nexouille Soft\arrm\Database\tosec\samples and %appdata%\Nexouille Soft\arrm\Database\dat\samples
                        • Fixed: On launch, error messages now appear after the Splashscreen
                        • Fixed: when creating M3U files on 1.9.1.2 Beta versions, sometimes spaces were added before the .m3u (thanks Cdaters)
                        • Fixed: The linked values ??displayed in the combobox associated with the 'DB fields' in the 'Search' tab take into account 'Show hidden' and are updated when entering the 'Search' tab
                        • Fixed: When deleting unused images, images referenced in <folder> tags are no longer deleted
                        • Fixed: The <emulator> tag is written again in gamelists when creating gamelists
                        • Fixed: Bug: Choosing Fanart in replacement modules caused a crash
                        • Fixed: Bug: Searching with MD5 on Screenscraper must give more precise results (passing the system as an argument)
                        • Fixed: Bug of previous Beta versions (only) which caused a slowdown when loading gamelist containing more than 1360 roms.
                        • Fixed: Bug that could occur following the implementation of API call limitations on HFSDB.
                        • Deletion: Button 'Delete Rom' of the panel 'Rom information': use the button 'Delete Rom' of the panel 'Possible actions on selected Roms'
                        Donwload links:
                        C 1 Reply Last reply Reply Quote 4
                          cdaters @nexusone13
                          I highly recommend this scraper! And if you are able, I suggest sending @nexusone13 some love! ARRM has so many more features than Skraper, (which seems to have stalled,) and development of this scraper app is very active.
                          ARRM makes short work of managing your gamelist files, and it works with different foundational platforms such as Batocera or Recalbox too. Unlike some additional setup steps to use Skraper on your PC (as opposed to directly on your Pi) ARRM allows you to work directly on your PC with whatever gamelist.xml file you give it.
                          The templates that you have access to for mix-art is amazing and configurable. Everything is configurable! There is in-line help, and/or the Wiki for more information/how-tos.
                          • nexusone13N
                            nexusone13 @cdaters
                            Thank you very much @cdaters for your encouragement, it makes me very happy.
                            Thank you also for identifying problems and suggesting improvements.
                            • ExarKunIvE ExarKunIv referenced this topic on
                              morenr1
                              Hi,
                              @nexusone13 for this excelent piece of software and for the continue improvement of the tool.
                              My question is related to subdirectories. I have some subfolders with artwork and samples with zip files inside. When I create the gamelist these samples and artworks appear in gamelist as a new entry.
                              Is there any way to avoid it, just scan the rom directory (parent directory) without subfolders?
                              workaround is mark as hidden these entries, but I wondering if there is other alternative.
                              moren1
                              • nexusone13N
                                nexusone13 @morenr1
                                Hi @morenr1 ,
                                If .zip is one of the searched extensions, ARRM will display it. It is not possible to indicate only the parent, since it is quite common to place roms in subfolders. That would be too many scenarios to handle. The solution to put in 'hidden', as you indicate, remains the solution. sorry
                                I just sent you an email (check your spam)
                                • nexusone13N
                                  Hi, @morenr1
                                  Could you contact me Nexusone13#8474 on our ARRM discord: https://discord.gg/p7QsBTS channel #arrm or in private
                                  Thank you
                                  • nexusone13N
                                    Hi everyone,
                                    1.9.1.3 (04/30/2022)
                                    • Added: Unitary or mass translation of Game Descriptions in the language of your choice. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=translate_description_en (thanks Schmurtz for the url)
                                    • Added: When several systems are checked, it is now possible to choose the scrape engine you want and no longer only Screenscraper
                                    • Added: When creating video with overlays, if auto template is not checked, ARRM will look in the 'templates_video' directory for a template with the same name as the template currently used by ARRM. If not present, ARRM will take the currently used template it finds in 'templates'. See Wiki : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=video_overlay_en
                                    • Added: Checkbox 'compress video+overlay' allowing to compress 'video+overlay' during their creation (the 'Compress video' checkbox no longer applies to 'video+overlay'
                                    • Added: In templates, layers can be applied depending on the format (Portrait, Landscape, CD) of Screenshot/Boxart/Cartridge/Boxback. See example with the mix_splash_MAME template from TVsIan (see wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=create_template-en#conditional_layers)
                                    • Added: In templates, screenshot can take Portrait, CD or Landscape attributes. See wiki: http://jujuvincebros.fr/wiki/arrm/doku.php?id=create_template-en#screenshot (see TVsIan template : mix_splash_MAME)
                                    • Added: When scraping on HFSDB if the game is not found with its MD5, a file %appdata%\Nexouille Soft\arrm\temp_missing_HFSDB_MD5_%system%.txt is created which could be useful to feed the HFSDB DB . See wiki: http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=scraper-hfsdb-en#list_of_md5_not_found (look at template : cd portrait landscape sample)
                                    • Added: 'Round Wheel (HFSDB / Screenscraper)' button in the 'Images Options' tab allows to recover the 'round wheels' on HFSDB and Screenscraper in the wheels directory. For Screenscraper the type (carbon or steel) can be selected in the 'Assignment media Screenscraper' module
                                    • Modification: Adaptation of certain forms so that essential information can be displayed on a resolution of 1280x720
                                    • Fixed: STOP button on multi-system scrape was not acting as expected
                                    • Fixed: Steam multi-system scrape not working
                                    • Fixed: A crash could occur when ARRM wanted to use a template referenced in template_association.txt when it no longer existed
                                    • Fixed: On Steam, some artwork found was not downloaded
                                    • Fixed: the 'Hide cue/gdi/m3u' button did not have the expected behavior (the files did not take the <hidden> tag when they were in subdirectories) thank you cdaters
                                    Donwload links:
                                    • Z
                                      ZzackK
                                      hi Program is great job.
                                      I have two small problems.
                                      -I can not skip by letter
                                      -Some games are not sort alphabetically
                                      • nexusone13N
                                        nexusone13 @ZzackK
                                        Hi @ZzackK ,
                                        Thanks,
                                        you should find anwser for your problem in the wiki .
                                        this is relative to the sortname tag option.
                                        So Check the "Remove Sortname Tag" and save your gamelist again
                                        wiki : http://jujuvincebros.fr/wiki/arrm/doku.php?id=settings-en&s[]=add&s[]=index
                                        • Z
                                          ZzackK
                                          thx
                                          • Z
                                            ZzackK
                                            I want use only "clear name" for my gamelist but I do not scraping all roms. Is possible do it fast?
