Lr-hatari it does not work
It was working without problem lr-hatari. Maybe when updating the system, it has stopped working. I have tried updating or uninstalling it and installing it again and nothing.
I installed lr-dosbox and lr-scummvm I do not know if it has anything to do with it.
pi@retropie:~ $ log Parameters: Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/Gremlins 2 - The New Batch (Europe).zip" --appendconfig /dev/shm/retroarch.cfg [libretro-test]: Got size: 640 x 480. Retro SYSTEM_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro SAVE_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro CONTENT_DIRECTORY /home/pi/.config/retroarch/downloads Retro DeInit
Your RetroArch configuration is changed from the default.
From the log file is looks like the ROM folder is set to/home/pi/.config/retroarch/downloads
instead of/home/pi/RetroPie/roms/atarist/
and the BIOS folder is set to/home/pi/RetroPie/roms/atarist/
instead of/home/pi/RetroPie/BIOS
.Rename the
file and then re-install thelr-hatari
package, this will re-create the default file with the correct settings. -
Thanks, it works as before.
I have same problem. I make the workarund but nor works for me.
Executing: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/F-19 Stealth Fighter.zip" --appendconfig /dev/shm/retroarch.cfg Retro SYSTEM_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro SAVE_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro CONTENT_DIRECTORY /home/pi/.config/retroarch/downloads Resolution 416 x 260. Retro DeInit
I make a reinstall form binary
Same problemExecuting: LD_LIBRARY_PATH='/opt/retropie/libretrocores/lr-hatari' /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-hatari/hatari_libretro.so --config /opt/retropie/configs/atarist/retroarch.cfg "/home/pi/RetroPie/roms/atarist/F-19 Stealth Fighter.zip" --appendconfig /dev/shm/retroarch.cfg [libretro-test]: Got size: 640 x 480. Retro SYSTEM_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro SAVE_DIRECTORY /home/pi/RetroPie/roms/atarist/ Retro CONTENT_DIRECTORY /home/pi/.config/retroarch/downloads Retro DeInit
@KoCinsKy It doesn't look like you applied the solution given in this topic. Have you removed/renamed the config file I mentioned ?
@mitu said in Lr-hatari it does not work:
Yes, before uninstalling and installing, I deleted the file and it is created later. But it does not change the paths.
Anything else that can be done to fix it?
@KoCinsKy Please add more info about your system, as detailed in https://retropie.org.uk/forum/topic/3/read-this-first. You can also run with
Verbose Logging
toggled from the Runcommand Launch menu and them upload the detailed log file to pastebin.com. -
Verbose Logging
toggled from the Runcommand Launch menu and them upload the detailed log file to pastebin.com.Pi Model or other hardware: Raspberry Pi 2 Model B Power Supply used: RetroPie Version Used (eg 3.6, 3.8.1, 4.1 - do not write latest): 4.5.1 Built From:nachos image USB Devices connected: keyboard Controller used: sf30 8bitdo Error messages received: Log found in /dev/shm/runcommand.log (if relevant): Guide used: (Mention if you followed a guide) File: (File with issue - with FULL path) Emulator: (Name of emulator - if applicable) Attachment of config files: https://pastebin.com/BXRKErTA How to replicate the problem:
@KoCinsKy said in Lr-hatari it does not work:
We dont's support 3rd party images, as outlined in the https://retropie.org.uk/forum/topic/3/read-this-first.
Your problem is the same as original poster (wrong BIOS folder location), I don't know why the fix doesn't work for you - but it might be additional configurations on your image that are not present in a RetroPie image. -
Ok, thx :(
I have the same problem, I just update all packages from retropie setup and lr-hatari stop working...
I already delete retroarch.cfg, uninstall and install, then only works for a once, the second time I launch it backs to the emulationstation.
@Rated-R said in Lr-hatari it does not work:
Please open a new topic, providing the info asked in https://retropie.org.uk/forum/topic/3/read-this-first and a verbose log as explained in the topic. Don't bump old topics.
