    Running advmame roms from USB drive
    16 Posts 6 Posters 5.0k Views
    • GabhanEISG
      GabhanEIS
      Reporting back - moving the entire roms folder to the USB drive and mounting the drive as /home/pi/RetroPie/roms works perfectly. I've added this to fstab and all seems to be working well. Many thanks for the help - my arcade buttons and joystick arrived today so now really looking forward to hooking everything up!
      briankrossB 1 Reply Last reply Reply Quote 0
      • briankrossB
        briankross @GabhanEIS
        @GabhanEIS said in Running advmame roms from USB drive:
        How did you mount the drive?
        • Brian
        • GabhanEISG
          GabhanEIS
          Not a linux expert by any means, but this is what I did:
          • Fresh install of RetroPie from the sdcard image
          • Run through the initial setup on the Pi - expanding the file system - until EmulationStation boots up
          • F4 to go to terminal - sudo su - to ensure permissions
          • cp -ar /home/pi/RetroPie/roms/ /media/usb0/
          • rm -rf /home/pi/RetroPie/roms
          • mkdir /home/pi/RetroPie/roms
          • mount /dev/sda1 /home/pi/RetroPie/roms
          • Copy some roms using samba from a PC/Mac machine to the correct roms folder
          • Restart EmulationStation and test roms work correctly - in my case they worked perfectly. This will work as long as /dev/sda1 is mounted at /home/pi/RetroPie/roms. However, this mount will not be there on reboot. To ensure it's automatically mounted, you can modify the fstab file as follows:
          • nano /etc/fstab
          • Add a line to the end of the file as follows
          • /dev/sda1 /home/pi/RetroPie/roms vfat defaults 0 0
          I just researched this on part on Google, so you need to make sure your usb drive is /dev/sda1 using the command df -h. Find your USB drive in the list and substitute as appropriate. There are lots of good Linux tutorials on this on the web. Hope this helps out other Linux newbies like myself. It's only an sdcard image anyway, so if it goes wrong and it won't reboot, you can just reload the sdcard from your PC.
          briankrossB 1 Reply Last reply Reply Quote 2
          • briankrossB
            @GabhanEIS
            Awesome, thank you. :)
            • Brian
              dankcushions Global Moderator
              i added the guide to the wiki: https://github.com/RetroPie/RetroPie-Setup/wiki/Running-ROMs-from-a-USB-drive
              it's slightly from memory and googling what i think i did before, so i hope there's no mistakes! please let me know/edit if so :)
              briankrossB herb_fargusH O 3 Replies Last reply Reply Quote 3
              • briankrossB
                briankross @dankcushions
                @dankcushions said in Running advmame roms from USB drive:
                Right on!
                • Brian
                • herb_fargusH
                  herb_fargus administrators @dankcushions
                  @dankcushions awesome thanks for doing that. I'm sure we'll automate it with a module sometime but the guide is great
                  • O
                    orgon3 @dankcushions
                    @dankcushions Thanks so much! After following your guide to the letter, it works, with a few caveats.
                    1. the copy command yields a few errors that it cannot copy symlinks
                    2. getting a weird "operation not permitted" even though ls -al shows full permissions for everyone. I am getting that when EmulationStation runs an sh command, and in retropie_setup.sh when updating certain emulators.
                    3. When attempting to play certain games/emulators (example, pc port, opentyrian) I get an "operation not permitted" error and I cannot play the game.
                    I didn't know how to fix it when it says it can't do something and I see the file permissions says it can ;_;
                    Perhaps all three are linked to the same issue? My fix for now would be to wipe my sd card, put on raspbian, setup the usb stick in fstab, and THEN start the installation?
                    dankcushionsD 1 Reply Last reply Reply Quote 1
                      dankcushions Global Moderator @orgon3
                      @orgon3 said in Running advmame roms from USB drive:
                      hmm, i think maybe a mv would be better than a copy?
                      sudo mv /home/pi/RetroPie/* /media/usb0/ - it's less steps, certainly! guide updated...
                      i'm not sure about the permissions thing, and i don't use any of the PC emulators/ports, so not sure about that :( possibly it has to do with relative symlinks - if any exist in retropie they need to be converted to hardlinks before they're moved. this is a bit beyond my linux level, so i'm just guessing here :(
                      • O
                        Well, the problem also occurs when attempting to upgrade. For me, a useful feature. In the end, I'll resort to having a few systems stored on my sd card and a few on my usb stick. I'll probably end just editing the cfg file for now and changing the specific system's path. Even installing just the core creates a symlink for genesis.
                        Thanks for your help though! I'm sure some linux guy will reply.
