    mame4all and cfg display problems
    6 Posts 3 Posters 1.7k Views
      alfredox123
      i want to edit manually the default.cfg of mame4all but it looks like this http://i.imgur.com/hSEzXMu.jpg?1
      anyway on how to fix it?
      briankrossB dankcushionsD 2 Replies Last reply Reply Quote 0
      • briankrossB
        briankross @alfredox123
        @alfredox123 said in mame4all and cfg display problems:
        Have you tried via SSH or quitting emulation station and try the command line instead?
        • Brian
          dankcushions Global Moderator @alfredox123
          @alfredox123 it's not user-editable. why don't you just use the TAB menu within the emulator?
            alfredox123
            the problem is that i changed all the default bindings on the keyboard, so there is no tab or any key related to keyboard , only esc to exit. and i only want to change the buttons for exit emulator thats all (which interfere with toggle menu buttons that i put)
              you'll have to delete the file so it returns to defaults
                alfredox123
                yeah that worked, and i made some keys to the keyboard in case it happens again, thx all :)
