    Dreamcast reicast not starting
    reicastdreamcastbioscontroller
    52 Posts 10 Posters 10.8k Views
      mitu Global Moderator @ilkayefe
      @ilkayefe Can you show a picture/screenshot of the image ?
      • EfriimE
        Efriim @ilkayefe
        @ilkayefe
        Go ahead and try all the buttons, if you can select the settings then it will be possible to map the controls from within the emulator.
        • I
          ilkayefe @mitu
          Also i tried all buttons to enter settings, but i cant enter.
          • EfriimE
            Efriim @ilkayefe
            @ilkayefe Open up the mapping file from earlier with edit+ "\configs\dreamcast\mappings\evdev_Microntek USB Joystick.cfg", as a second task start the the reicast input configuration and map each button, after each input press copy the three-digit number of the input into edit+ to replace the three-digit numbers in the map file.
            • I
              ilkayefe @Efriim
              @Efriim
              Hi,
              My configs are already this.
              [emulator]
              mapping_name = Microntek              USB Joystick
              btn_escape = 296
              [dreamcast]
              btn_a = 288
              btn_b = 289
              btn_x = 290
              btn_y = 291
              btn_start = 297
              axis_x = 0
              axis_y = 1
              [compat]
              axis_dpad1_x = 17
              axis_dpad1_x_inverted = no
              axis_dpad1_y = 16
              axis_dpad1_y_inverted = no
              btn_trigger_left = 292
              btn_trigger_right = 293
              axis_x_inverted = no
              axis_y_inverted = no
              • EfriimE
                Efriim @ilkayefe
                @ilkayefe
                If the numbers are the same, then it should work. You could try moving the maps as a temporary backup and then copying this map and renaming, it. It is obvious one of them was working but I can't say for sure what namespace it is actually using.
                evdev_Microntek              USB Joystick          .cfg
                controller_MicrontekUSBJoystick.cfg
                • I
                  ilkayefe @Efriim
                  @Efriim Hi,
                  I have good news, its worked. I have entered to settings.Thank you so much for your helps.
                  • L
                    lordm60 @ilkayefe
                    @ilkayefe
                    I had the same problem as you, I followed exactly and managed to get into the "Settings". Would like to check with you whether the controls mapped in this "Settings" works for you when you launch the games? None of the controls worked for me when I launched any games in Reicast, but it works for other emulators.
                    If I use lr-flycast, the controller definitely works, just that I have to manually go inside the game to change the buttons mapping each time.
                    Just for info:
                    Pi Model or other hardware: Pi3 B+
                    Power Supply used: 5V, 2.5A
                    RetroPie Version Used: ver 4.4.14
                    Built From: Pre made SD Image on RetroPie website - retropie-4.4-rpi2_rpi3.img
                    USB Devices connected: DragonRise Inc. Generic USB Joystick, USB minikeyboard
                    Controller used: DragonRise Inc. Generic USB Joystick
                    Error messages received:
                    Emulator: reicast (I have lr-flycast installed as well)
                    EfriimE B 2 Replies Last reply Reply Quote 0
                    • EfriimE
                      Efriim @lordm60
                      @lordm60
                      Most emulators are retroarch cores, which share a common feature of automatic gamepad mapping. The standalone emulators have their own configuration files and control maps, and the recently developed and updated ones fall away from the automatic configuration that is also part of RetroPies scripts.
                      I'd say that mapping using the new GUI settings in reicast will most definitely work, as long as you can pull it off with what is given. Good luck though, and have fun.
                      • L
                        lordm60 @Efriim
                        @Efriim
                        I will share if I manage to get it to work though, I couldn't get the controller to get into the "Settings" initially till I found this thread and I followed it through. Now the challenge is to get it to work in the games.
                          bladeas @lordm60
                          @ilkayefe said in Dreamcast reicast not starting:
                          @Efriim Hi,
                          Hi Ilkayefe,
                          I have the same issues with the same joystick, please could you tell me how you solved the problem?
                          Thank you
                            Plex7
                            I am having issues as well. I tried configuring the joystick.cfg by manually mapping as instructed and I also reset my emulation station controller inputs (so it auto configures reicast) and it still didn't work. This has been an ongoing issue for years now, they should update this emulator.
                            My only other alternative is to overclock my pi and pray lr-flycast performs better. Otherwise, I am stuck.
