    Driver for the Retro-Bit NES not working
    retro-bit nes
    10 Posts 2 Posters 502 Views
      rgrs
      Pi model: Pi B rev 2
      Power supply: Nokia 5V 2A
      RetroPie version: 4.4.14
      Built from: retropie-4.4-rpi1_zero.img
      USB devices connected: Retro-Bit NES Controller
      Controller used: Original NES controller
      Error messages received: No gamepad detected
      Guide used: https://github.com/msteinbeck/hid-retrobit
      Emulator: Emulation Station
      How to replicate the problem:
      I rebuild my old defective NES with an RPI and installed a clean retropie on it. I installed the drivers for the controller. They do show output when using the command: jstest /dev/input/js0
      When I start retropie, I get the message "no gamepad detected". I know this isn't the best controller, but I wanted to keep the original NES look and gamepads. Can't get them to work in retropie. I haven't looked into recompiling my own kernel yet.
      Out of the box it doesn't work at all.
      Any suggestions?
        mitu Global Moderator @rgrs
        @rgrs Did you copy the udev rules - as explained in the driver documentation ?
        Unfortunately, the driver hid-generic prevents hid-retrobit from binding your device. The file 99-hid-retrobit.rules contains some udev rules which unbinds all supported devices from hid-generic and rebinds them to hid-retrobit on the fly. Copy this file to /etc/udev/rules.d. To ensure the udev rules are able to rebind your devices, you finally need to copy the file hid-retrobit.conf to /etc/modules-load.d.
          rgrs
          I did.
          I will have another go at it, as I have been messing around a lot.
          @mitu I did copy these files, however, this is for the manual installation.
          All I have to do is:
          Download the latest deb package from: https://github.com/retuxx/hid-retrobit/releases.
          Install linux headers and dkms:
          sudo apt-get install raspberrypi-kernel-headers dkms
          Install the driver:
          sudo dpkg -i hid-retrobit.deb
          Plugin your device.
            @rgrs OK, but did you check if those udev rules are added after the installation ? Maybe they're important and need to exist in order to have a functioning driver.
              rgrs @mitu
              Before installation of the driver:
              etc/udev $ ls
              hwdb.d rules.d udev.conf
              Installation:
              Selecting previously unselected package hid-retrobit.
              (Reading database ... 96597 files and directories currently installed.)
              Preparing to unpack hid-retrobit.deb ...
              Unpacking hid-retrobit (1.0.0) ...
              Setting up hid-retrobit (1.0.0) ...
              Creating symlink /var/lib/dkms/hid-retrobit/1.0.0/source ->
              /usr/src/hid-retrobit-1.0.0
              DKMS: add completed.
              Kernel preparation unnecessary for this kernel. Skipping...
              Building module:
              cleaning build area.........
              make -j1 KERNELRELEASE=4.19.42+ -C /lib/modules/4.19.42+/build M=/var/lib/dkms/hid-retrobit/1.0.0/build..............
              DKMS: build completed.
              hid-retrobit:
              Running module version sanity check.
              • Original module
                • No original module exists within this kernel
              • Installation
                • Installing to /lib/modules/4.19.42+/kernel/extra/
              depmod.....
              DKMS: install completed.
              after installation:
              /etc/udev $ ls
              So it seems there were no changes made. I will copy the files to the required dirs.
                rgrs
                Well, I was looking in the wrong dir. But the files are there after installation
                No gamepads detected unfortunatly.
                dmesg output:
                [ 208.530291] usb 1-1.2: reset full-speed USB device number 4 using dwc_otg
                [ 209.281657] usb 1-1.2: USB disconnect, device number 4
                [ 220.180609] usb 1-1.3: new low-speed USB device number 5 using dwc_otg
                [ 220.325589] usb 1-1.3: New USB device found, idVendor=1292, idProduct=4643, bcdDevice= 2.01
                [ 220.325618] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
                [ 220.325631] usb 1-1.3: Product: NES Controller USB
                [ 220.325644] usb 1-1.3: Manufacturer: INNEX
                [ 220.351132] input: INNEX NES Controller USB as /devices/platform/soc/20980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:1292:4643.0005/input/input7
                [ 220.357206] hid-retrobit 0003:1292:4643.0005: input,hidraw0: USB HID v1.00 Gamepad [INNEX NES Controller USB] on usb-20980000.usb-1.3/input0
                Really weird: the inputs are working fine
                pi@retropie:~ $ jstest /dev/input/js0
                Driver version is 2.1.0.
                Joystick (INNEX NES Controller USB) has 2 axes (Hat0X, Hat0Y)
                and 4 buttons (BtnA, BtnB, BtnC, BtnX).
                Testing ... (interrupt to exit)
                Axes: 0:-32767 1: 0 Buttons: 0:off 1:off 2:off 3:off (Left)
                Axes: 0: 0 1: -32767 0 Buttons: 0:off 1:off 2:off 3:off (Up)
                Axes: 0:32767 1: 0 Buttons: 0:off 1:off 2:off 3:off (Right)
                Axes: 0: 0 1: 32767 0 Buttons: 0:off 1:off 2:off 3:off (Down)
                  The log shows the device is using the driver, jstest works, maybe SDL2 doesn't detect it. Try adding an udev rule for it - similar to what's described here. Replace Vendor/Product IDs with the values from the log. Reboot and see if it gets detected by Emulationstation.
                    rgrs @mitu
                    This is already in 99-hid-retrobit.rules
                    only match one vendor and product
                    ATTRS{idVendor}=="1292", ATTRS{idProduct}=="4154", GOTO="hid_retrobit_ok"
                    ATTRS{idVendor}=="1292", ATTRS{idProduct}=="4643", GOTO="hid_retrobit_ok"
                    ATTRS{idVendor}=="1292", ATTRS{idProduct}=="5346", GOTO="hid_retrobit_ok"
                    ATTRS{idVendor}=="1292", ATTRS{idProduct}=="4745", GOTO="hid_retrobit_ok"
                    Ok, I unloaded 99-hid-retrobit.rules to see what would happen. But jstest still works fine. I did not expect to see that.
                      rgrs
                      @mitu is it possible to setup the controller manuallly in retropie somehow? I can't figure out anything wrong with the driver.
                        @rgrs You can set it up manually, but if it's not detected by Emulationstation it will not work in it. You can however set it up in RetroArch - https://retropie.org.uk/docs/RetroArch-Configuration/#autoconfigurations. Get the button values and add them to a .cfg file named after your controller - there's an example in the doc page.
