    !retro bang for DuckDuckGo search engine
    duckduckgosearchbangretroforum
    11 Posts 3 Posters 1.5k Views
    • thelostsoulT
      thelostsoul
      Hello guys. If you are familiar with DuckDuckGo, an alternative search engine for the web, you probably know the "!Bang"-feature. Month ago I registered my own bang and got the confirmation just a couple minutes ago. The search bang is:
      • !retro SEARCHTERM
      and searches this forum with the search function of the forum itself. This works in every environment where you use the search engine DuckDuckGo, in example in the address bar of Firefox. The URL-template is this:
      • https://retropie.org.uk/forum/search?term=SEARCHTERM&in=titlesposts&matchWords=all&sortBy=relevance&sortDirection=desc&showAs=posts
      If you have any suggestion, I can update the bang. Do anyone use DuckDuckGo.com?
      Edit:
      A new bang is registered. I don't create a new thread for it, as it is for a different site.
      • !hack SEARCHTERM
      This one will start a search in the https://www.romhacking.net/hacks/ website. It will sort the romhacks by date, so you see the newest entries first.
      📜 RE/SET: 100 SNES Games for your RetroPie, 🎁 Share your hidden gems and insider tips
        Nice effort !
        As a suggestion, try limiting the search to the last year posts, the forum search is - hopelessly - prioritising older posts over newer ones. I sometimes search for old topics where I replied and found a new solution and I always have to use the time filter to narrow down the search to find something relevant.
        thelostsoulT 1 Reply Last reply Reply Quote 0
        • thelostsoulT
          thelostsoul @mitu
          @mitu I remember wanting to do this, but this would be my personal preference and I thought the default is the best option. I think I should have discussed it with you here before registering. So the next priority is to update the template.
          If the search limited to last and current year, then older postings wouldn't be found and that's not a good solution. There are many older postings, like list of games or older solution to problems will have in the future too. Edit: typo corrected
            mitu Global Moderator @thelostsoul
            @thelostsoul said in I have registered !retro bang for DuckDuckGo search engine:
            You're right, for anything outside the help & support category, limiting the results to only 1 year is not helpful. Limiting by time is not a good idea, just leave it as it is.
            • thelostsoulT
              thelostsoul @mitu
              @mitu How well does the sort function work? The default is sort by relevance and maybe thats why some older postings are prioratized. They have just more content matching the search terms maybe. The results seem to be a mix as new and old content are shown. Maybe you are right and I just leave it as it is.
              • hiulitH
                hiulit
                Thanks! That's a great feature!
                I've been using DuckDuckGo for a while now and I really like it. Didn't know about bangs and they are great.
                Just a little thing, wouldn't it be more suitable if this bang would be called !retropie? I mean, retro is a really wide term, right? Anything can be retro :P
                Anyways, thanks for making this happen. Really appreciate it ;)
                My little contributions to the RetroPie project:
                • Shell-Script-Boilerplate
                • Fun-Facts-Splashscreens
                • Limit-Last-Played-Games
                • thelostsoulT
                  thelostsoul @hiulit
                  @hiulit well there are two reason for it. One is, it is shorter and faster to type. I even wish it would be just !r or !rp. Less prone to errors, was it pi or pie in example. And also registering !retro as first is like "who gets it first, earns it". Well, we could also register !retropie. Lol I just tested and !pie is free too.
                  hiulitH 1 Reply Last reply Reply Quote 0
                  • hiulitH
                    hiulit @thelostsoul
                    @thelostsoul hahah ;) First come first served ! I think !rp would be also a good one, and is even shorter
                    • thelostsoulT
                      thelostsoul @hiulit
                      @hiulit yeah :D Unfortunately my top choice !rp is already taken by raspberrypi.org. They was faster than me.
                      • hiulitH
                        hiulit @thelostsoul
                        @thelostsoul Well, good for them ;) We'll stick with !retro.
                        • thelostsoulT
                          thelostsoul
                          A new bang is registered. I don't start a new thread for this, as it is for an external site and not about Retropie itself (and to be honest, its not that important).
                          • !hack SEARCHTERM
