    Atari 800 controller problem
    atari 800
    4 Posts 2 Posters 807 Views
      PCKid
      Finally with help from here got it all working. All games work fine as Atari Joystick Controller except Caverns of Mars. It worked fine then I did something in the Select+X menu and now it only fires. D Pad direction won't work. Left Shoulder button level select works and Start starts it OK. Somehow I've stuffed up direction control. Is there a specific config for each game? So maybe I could delete it and redo it? I've got a Shanwan PS3 Bluetooth Controller. All other emulators work fine with it. Literally just this one game. One of my all time favourites and the first game I bought with my Atari 800 so real nostalgia kick there.
      • rkosterR
        rkoster
        This sounds like you have saved a custom config for just this game.
        If I recall correctly, it is located in
        /opt/retropie/configs/all/retroarch/config/Atari800
        You can navigate to there on the command line and delete the Caverns of Mars.cfg that is probably there.
        Github/helper scripts * Creativision/Arcadia/Astrocade guide * Amiga guide * Atari 8bit guide
          PCKid @rkoster
          @rkoster turns out I needed to select PAL instead of NTSC then the controller worked.
          • rkosterR
            rkoster
            Huh, changing that shouldn't have mattered, especially given that the game was originally NTSC!
            You might want to look at the script I wrote here: https://retropie.org.uk/forum/topic/22392/lr-atari800-5200-artifacting-basic-and-other-guidance/17 if you want to get hardcore on Atari800 emulation.
            Also might want my fixed build of the emulator, if you ever want to play anything that requires typing. https://retropie.org.uk/forum/topic/22460/fixed-ctrl-and-shift-on-lr-atari800
